Designer King
Stacking Wheel Spacers
I have 7" x 16" Fuchs all around on my S. I have used 6.5mm spacers on the rears for years, using the stock stud bolts. I have 2 more spacers which I would like to use in order to move each of the rear wheels out a further 6.5mm. According to Elephant I would need new 66mm studs if I have 13mm of spacer.
Provided I install the new 66mm studs, can I stack the 2 spacers on each wheel? I don't track the car so this is just for street driving.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 05-06-2019 at 05:02 PM.. |
Depends on if they are simple flat spacers, or if they are hub centric and have a lip for the wheel to center on. If they are flat they will be too thick for the wheel to center on the hub and you'll need to buy a set of hub centric spacers. So flat no, hub centric yes.
The aluminum spacers I've bought from eBay have been shockingly nice for practically zero dollars. I bought three different sizes from various vendors and all have been great. Something like this:
To better answer your question, I don't think you'd have an issue as long as you end up hubcentric as noted above, but like making a copy of a copy, the slight tolerances can add up, so it's not ideal if you can avoid it.
Matt - 84 Carrera |
I'm good with tools.
I wouldn't use a spacer (of any type) on a wheel for any reason..... The correct offset is the only way to go. That's my opinion and nothing more.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Designer King
Thanks for the replies. They are what I expected. The current spacers are not hubcentric, so I think I'll stay with what I have for now, but I'm not ruling out Matt's suggestion.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
New-ish 911SC Targa Owner
For my 16"x7" rears, I used these 1" spacers. I don't have any rubbing and run around 2 deg neg camber.
These are hub centric and cost $65 shipped. Sourced from eBay. looks much beter imo: ![]()
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Fwi. Porsche used spacers on all the 930's from the factory. Almost all older 911s are running spacers of some type and that includes track cars so I don't think there's anything inherently wrong with them if common sense rules are adhered to.
