-   -   Another CIS mystery under way (http://forums.pelicanparts.com/porsche-911-technical-forum/102893-another-cis-mystery-under-way.html)
RoninLB 03-20-2003 06:00 PM
Originally posted by jason2guy
whats going on here??
that means you can't lower the idle from the 1700 rpm after it warms up??
jason2guy 03-20-2003 07:20 PM
sometimes it goes back to normal idle after it warms up and then after a while it decides to go to 1500-1700 and sometimes 1200.
im starting to think a faulty AAR
bigchillcar 03-20-2003 08:04 PM
I second a prior suggestion...I would get get the car to exactly 180 (operating) degrees and turn the idle air-bypass screw clockwise until my idle was ~ 1000 to get the proper baseline established. Then I would check timing with the light and proper dwell with dwell meter. Next, take carb cleaner and spray in the vicinity of the airbox and see if the idle increases temporarily (leak). These are the quick and easier diagnostics to try. After rough check of mixture, if you don't have the CO equipment, is check the condition of your spark plugs. They will tell a lot about your mixture conditions. If they look good, odds are your mixture is ok. If they are 'whitish', probably lean...if otherwise, probably rich. Beyond this, I would consider a trusted mechanics opinion.
Ryan
diy83sc 03-20-2003 08:05 PM
My 83 is doing the same thing right now. With outside temps 50 F. and less, from cold start it slowly climbs to about 2K, then slowly works it's way down to 950, where I've set the idle. Total time ~ 10 minutes. I think that the AAR element is not warming up or it is stuck. I am going to try tapping it (per JWW) with a hammer first, then remove and clean it if it works. I may even take the time to test for voltage.
jason2guy 03-20-2003 08:26 PM
the AAV is brand new, but i suspect something is going on with it. i think its the source of this idle problem. the auto parts store i bought it from will exchange it for a new one. im gonna try that this weekend and see what happens. plugs are new
RoninLB 03-21-2003 05:14 AM
so this idle problem started happening when you changed the AAV ????
jason2guy 03-21-2003 07:35 AM
bad guess
RoninLB 03-21-2003 07:39 AM
I'd disconnect your deceleration valve to see what happens..
jason2guy 03-21-2003 07:47 AM
havent completly read the thread huh?
RoninLB 03-21-2003 08:19 AM
bad guess, LOL.. I'm just trying to get a solid baseline when this started happening and exactly how it sometimes happens..
like, "sometimes it goes back to normal idle after it warms up and then after a while it decides to go to 1500-1700 and sometimes 1200".. so this happened at idle all by itself, or after decelerating..
and my suggestion to eliminate the deceleration valve is that it can sometimes confuse the answer. the deceleration valve can cause problems with idle.. also the AAV and vacuum leaks are the routine answers. even the accelerator pedal, cable, or throttle valve binding..
jason2guy 03-21-2003 08:37 AM
its not the same everytime. sometimes it happens after 2 minutes from a cold start, and sometimes it happens after an hour of driving. it started happening 5 days ago, 2 months after replacing anything
ive tried just about everything short of pressure testing the CIS.
ill put money on the AAR being defective
RoninLB 03-21-2003 02:47 PM
the AAR has the elec connections..then when you clamp the AAR hose at high idle, the high idle decreases.. the AAV may cause cold start surging
diy83sc 03-21-2003 06:10 PM
If it looks like a nail, hammer it! I was experiencing long warmups due to idle staying high, and fan pushing cold air through engine compartment. I read another post (oh the power of information) suggesting a light tap with a hammer to the AAR and see if the idle drops... and it did. Now I will take the AAR off and give it a good cleaning. Thanks JW!
jason2guy 03-22-2003 07:43 AM
i bet youve never heard this one. i pulled the AAR last night to exchange it, so i figure lets go ahead and test it on the kitchen table. i hook up a 12V power source and over about 1 minute or so, watch it close completely.
so i think, well there goes that theory. i leave it hooked up for a while to make sure it stays closed. i start to wonder if just being closed all the way is enough to prevent air from pasing through and decide to blow through it, and i can. not a little either, a lot!!!!
the disk that is inside of the valve was not creating a good enough seal to prevent the air from passing. is that unreal or what!!??
im gonna put in the new one today and hopefully cure the high idle
jason2guy 04-08-2003 09:26 AM
im goin crazy. its up to 4 now. ive had 4 AAR's and i can blow through each one of them while fully closed. per the haynes manual i disconnected a hose from the AAR plugged both openings and the problem is gone (high idle when warm). am i crazy or are all the new AAR's faulty. help please
Jim Sims 04-08-2003 10:19 AM
I don't think the AAR's are "air tight" even when fully closed; see the comment about notches in the shutter in the following thread:
http://forums.pelicanparts.com/showthread.php?s=&threadid=64178&highlight=Auxilli ary+AND+Air+AND+Regulator
Jim
RoninLB 04-08-2003 11:02 AM
I just went thru a lot of CIS books.. and the AAR test is routine.. nowhere is it mentioned that it you should pass air thru it when warm to test for air tight.....Ron
tsuter 04-08-2003 11:09 AM
Air passes one way but not the other when closed. That is by design. You are blowing in the wrong end.
jason2guy 04-08-2003 11:17 AM
im blowing in the wrong end......
stupid me
air passes both ways genius
Jdub 04-08-2003 12:09 PM
I had always been told that some air will pass through the AAR. In fact, even with the car warm, I will return to it, fire it up, and it high idles for a short bit of time. My assumption was that current was shutting it down again. God knows the footprint of the base of the AAR is wide enough to pick up heat from the block it sits on. That has to effect things as well.
But I read this thread and I keep coming back to vaccum lines that appear near new but, under heat, expand and show minute cracks that allow air in. That would at least explain the higher idle. Or a crack in the plenum or loose hose on the backside of the throttle body.
What happens to the high idle when you pull the oil cap? Could this be as simple as a bad gasket at the cap?
Sorry to be so clueless. I am dying to hear the resolution to this one.
John
