lifting the car
Thanks all for responding...but here are my concerns: 1. your overwhelming suggestion is to remove myself the wheels and bring them to costco to replace the tires and balance them. I will be quite nervous of having the car mounted on support jacks stands on all 4 wheels which means raising the car on each side and placing the stands and hoping for stability after removing the wheels.
2. in my initial posting I suggested a method to be used by costco to use the back torsion tubes and the front bracket support of the tubes as displayed by our host's book...I would love to hear your opinions and/or experiences on this method...thanks
Old 05-09-2019, 12:44 PM
You probably wonít be permitted on the Costco service floor (insurance reasons) to explain the pick up points youíre suggesting. These cars can be jacked up safely and remain on jack stands without concern. If truly worried, consider buying just the tires at Costco and take them to a reputable P-car shop that balances tires.
Old 05-09-2019, 01:54 PM
Do it David! We all went through this the first time. We're here to help.
I start by lifting the back then the front. Wiggling the car at each step to ensure stability etc.
PM me if you want. Eventually, you can do your own rotors, brake pads, calipers, etc. I'm a believer of the saying, "If you want something done right, do it yourself".
Old 05-09-2019, 03:58 PM
Walt Fricke's Avatar
David - the method you mention - back T tubes, front bracket over front of A arm - works just fine. The car is adequately supported, and won't fall over on you.
Break the lug nuts loose before raising the car up. Torque when you put the car back on its wheels and on the ground.
Old 05-09-2019, 04:53 PM
SoCalSK8r's Avatar
I take the wheels off the car and bring them to the shop. I donít trust the ass monkeys at tire shops.
Old 05-09-2019, 05:08 PM
Reiver
Reiver's Avatar
Originally Posted by Uwon View Post
There are 10mm (check size) threaded holes at each corner of the belly pan, just next to the pinch welds. Get yourself four hockey pucks, drill out the centre, including a recess for the bolt head and screw them in. As I recall, on one corner I also had to saw a slit on the puck as the threaded hole is too close to the pinch weld.
Johan
911 SC going in for paint tomorrow and obviously some disassembly...I had 4 pucks and just mounted them...took no time at all...I spent more time in my bolt bin looking for the 4 bolts...I'll prob remove them when it gets back but a nice safety feature for piece of mind.
I had to shave a bit of a corner on the two rear ones but that took a long second on a grinder.
Great idea.
De Oppresso Liber
Old 05-09-2019, 07:15 PM
Counterclockwise?
David.
1. There are lots of local members (including myself) that can help you put you car on jackstands. Why Costco? There are many places in the GTA that know what they are doing.
2. If you are talking about jacking on the support locations, don't even think about it.
Rod
1986 Carrera
2001 996TT
Old 05-10-2019, 05:19 AM
rnln's Avatar
Everyone is worrying about others jacking up your car. No one worries about them "over-shooting" your lugs/nuts? :lol:
Fat butt 911, 1987
Old 08-31-2019, 12:15 AM
Shop for tire shops like you shop for tires. In my town there are a few small, independent tire shops that also sell Michelin, BFG, etc. You might pay a buck or two more, but you may be able to be right there while they lift your car. Not everyone has the space, proper tools or inclination to remove all tires and wheels and lug them to Costco.
Old 08-31-2019, 07:43 AM
I take mine one at a time! Normally replacing either both fronts or both rears not all 4 at the same time, so works for me and tire place just around the corner.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 08-31-2019, 08:01 AM
3rd_gear_Ted's Avatar
My car survived some serious jiggling sitting only on jack stands during the last 7.0 earthquake in our region.
1980 911SC
Fiberglass Turbo Flares F&R with a 3.6L conversion
869#
AKA "Gemma"
Old 09-01-2019, 08:38 AM
Originally Posted by rnln View Post
on my 911, I take off the wheels and bring them to tire shop.
+1
Not to mention they use their air wrench haphazardly scratching your Fuchs, and sratching the paint off your lug nuts. I take off my tires by placing a thin rag over one lug at a time, then I use a teflon socket over that. Then I use my torque wrench cautiously. But that's just me.
Old 09-01-2019, 01:43 PM
Originally Posted by chrisbalich View Post
I've been working on being nicer.
My natural disposition is alleged to be too abrasive for polite society.
Plus there's no need to disparage anyone who works at Costco . They already work at Costco. They understand perfectly well there's room for improvement.
Last time I was in a Costco tire shop was like 30 years ago. Will not ever go near them again. I brought my daughter's 900 Saab turbo in for tires, and the "tech" [more like a young punk] refused to install anything but the top line 150 MPH rated tire because it was a TURBO!!!
That car had a 2 L turbo engine with 135 HP!!! And my daughter drove it 5 miles to college on city streets. A long noisy argument resulted. I know a bit about tires and have worked in the auto industry for many years. AND I TOLD HIM SO.
I have been good to word in never spending another tire dime with Costco tire department. That punk cost them a lot of $$$ over the years....also all my friends and family have heard this boring story from me and I tell them how bad Costco is for tires.
My current system is to buy tires at Tire Rack, America's tire or others and pay to have them installed at the local shop. Last set I bought was from Tire-Easy.com and their prices and service is better than tire rack.
I just jack up the 911 the car in my garage, put it on stands, remove the wheels and deliver them to the tire shop for mounting. Usually cost $20/ wheel. Well worth it because the savings are so huge.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 09-01-2019, 07:43 PM
Other Hockey Puck Lift Pads
These are another nice hockey puck solution which locks into later Carrera lift points.
Jack Pad, Lift Pucks for your 911 Carrera, Boxter, Cayman
Old 09-01-2019, 08:25 PM
83 SC
ramonesfreak's Avatar
Last time I had a non-Porsche type shop install tires, they destroyed my rocker covers by using the wrong lift. Not to mention the horror of seeing an 18 year old kid trying to drive the car from the lot into the shop. Start, stall, start, stall......Thanks Firestone. Absolutely not worth it. Go to a shop that at least specializes in European sports cars, preferably vintage. In Toronto there must be a ton of these in the area
Edit...they also dented an oil line
1983 911sc
2017 Jeep Grand Cherokee Limited
Old 09-02-2019, 02:29 PM
Burnin' Rubber
Koizumi's Avatar
Originally Posted by robertmark View Post
+1
Glad Iím not the only one
'84 911
'95 840Ci
Old 09-02-2019, 09:22 PM
wrxnofx's Avatar
+1
You're worried about scratching lug nuts?
Yikes, it's a Porsche, not a puppy. Your head would have exploded if you had seen me take a sawzall to mine to cut the trailing arm bolts to get the trailing arms off. Or the angle grinder to my exhaust nuts to swap the catalytic converter for a cat bypass.
I guess it's a good thing we're not all alike, for the world would be a boring place...
1987 911 Carrera coupe - Guards Red
2005 Mini Cooper Convertible (R52) - Wife's car
Old 09-03-2019, 07:46 AM
