Question lifting the car
1987 carrera.
I am getting new tires installed and in reviewing the lifting points of my 87 Carrera, and matching it to the lift used at "Costco" tires garage, i came to the conclusion that the square lifting points of the car are quite small and 2 of them are very close to my AC and oil hoses and the flat bed of the lift arm might cause damage.
Costco does have a lifting V shape pad replacing the large square one and the best place to lift the car are the bac and front TORSION tubes as described in our host 101 projects book.
Does anyone used both front and back Torsions to lift the car? 5 ft. or so above ground? any opinions?
Old 05-08-2019, 09:44 AM
Driver
Noah930's Avatar
An alternative is to place a jack pad into the receptacle under the door, jack up one side (and replace the tires), and then repeat on the other side of the car. Have had tire shops do that in the past. Avoids exactly the concerns you've raised.
1987 Venetian Blue (really looks like grey) 930 Coupe
Old 05-08-2019, 10:31 AM
Counterclockwise?
Hand them 4 hockey pucks.
So many cars have been damaged by tire monkeys.
I'd go somewhere else.
Rod
1986 Carrera
2001 996TT
Old 05-08-2019, 10:39 AM
Any reputable tire shop will have spacers for their lifts. If nothing else you can request them to use floor jacks and hand them a jack adapter if they don't. I worked at a tire shop in college and I can't imagine they have less options 24 years later.
Old 05-08-2019, 11:37 AM
Thus far, no warnings about exposed and fragile oil lines often flattened by errant lift practices?
Let this be fair warning or merely a reminder.
Old 05-08-2019, 12:10 PM
Your asking for trouble, wouldn't let anyone jack up my Porsche unless I knew them.
Our society lacks common sense more and more everyday.
Old 05-08-2019, 12:14 PM
That's exactly what I did at Costco when I got my last set of tires.
They had no problem doing it that way. Very simple solution!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-08-2019, 12:17 PM
rnln's Avatar
on my 911, I take off the wheels and bring them to tire shop.
Fat butt 911, 1987
Old 05-08-2019, 01:05 PM
Can you take them just the wheels?
Old 05-08-2019, 01:09 PM
I echo the sentiments above. Bring the wheels to them & inspect your pads, lines etc. while you have the wheels off.
Old 05-08-2019, 03:36 PM
wareaglescott's Avatar
I have a 2 post in my garage and lift the car by the rear torsion bars and two points up front that avoid the oil lines and ac hoses. I would have a hard time trusting anyone else to do it. I just take the wheels off and take them to the tire place but that is harder to do if you dont have a lift.
Old 05-08-2019, 04:27 PM
Rescuer of old cars
Arne2's Avatar
^ This. I have a good shop I patronize, but I don't let them jack up my Porsches.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
1972 911T coupe
Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-08-2019, 05:04 PM
Uncertifiable!!!
Uwon's Avatar
There are 10mm (check size) threaded holes at each corner of the belly pan, just next to the pinch welds. Get yourself four hockey pucks, drill out the centre, including a recess for the bolt head and screw them in. As I recall, on one corner I also had to saw a slit on the puck as the threaded hole is too close to the pinch weld.
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 05-09-2019, 03:37 AM
scumbag
Check here. I did just as Johan advised.
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
IG: @doktor_b
Old 05-09-2019, 06:34 AM
Counterclockwise?
He has an 87. There are factory pads in place.
Rod
1986 Carrera
2001 996TT
Old 05-09-2019, 06:58 AM
scumbag
Apologies. Figure a tire tech can hit a bigger target with greater success, assuming the pads on an 87 are located the same as on a 79.
Easy to miss a small square, hard to miss a hockey puck.
IG: @doktor_b
Old 05-09-2019, 07:06 AM
Counterclockwise?
You call a tire monkey at Costco a tire tech.
Rod
1986 Carrera
2001 996TT
Old 05-09-2019, 07:10 AM
scumbag
I've been working on being nicer.
My natural disposition is alleged to be too abrasive for polite society.
Plus there's no need to disparage anyone who works at Costco. They already work at Costco. They understand perfectly well there's room for improvement.
IG: @doktor_b
Old 05-09-2019, 07:18 AM
gwinnch's Avatar
+1 on removing the wheels and dropping them off.
1985 911 Targa
Old 05-09-2019, 07:20 AM
Location: behind the redwood curtain, (humboldt county) california
Costco tire "technicians" jacked up my wife's Volvo wagon with a floor jack under the thin sheet metal "toe control arm, bending it so badly the tire had about 1/2 inch of toe out and the new tire lasted about a thousand miles.
Additionally, before the new tires were installed, the right front tire was almost worn down to the chords on the inside - the ball joint was extreamly loose and they failed to report this to my wife's family, (prior owners).
I know it is a lot of grunt work, but taking the tires off yourself and taking them to the tire shop is the safe way to go unless you either supervise the work, or have someone "skilled" make sure it gets done right.
Good luck,
chris
Old 05-09-2019, 10:14 AM
