Born to Lose, Live to Win
ramonesfreak's Avatar
whats this inside door - dent removal question
I had my door panels off to address some things and to take a look around inside the door. I have an appointment with a good PDR guy in June who said he might want to take my panels off (he hasnt seen car yet). No way I would let him take these panels off so figured I would drive it to him without the panels
but, then I saw this below in pic. One of my dings is directly on the other side of it
Did the car come from the factor this way?
Any thoughts on how this will impact his ability to get behind the ding if needed?
So much of what PDR guys do is a mystery so I have no idea if its worth the time to bother taking them off now
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 05-09-2019, 02:00 PM
Len 911's Avatar
Sound deadening pad..remove it and install newer type.
Old 05-09-2019, 02:10 PM
Cairo94507's Avatar
Len 911 is absolutely spot on. Factory sound deadening panel that is placed in the doors to avoid that tin can sound when you shut the odor and also reduce noise when driving. Remove and then replace with new stuff. It is not necessary to 100% cover the inside of the door. But most will significantly increase coverage when they add new stuff. Good luck with the PDR guy- they can work magic. Cheers, Michael
'71 914-6 #0372
'17 Macan GTS
Old 05-09-2019, 02:41 PM
You will need to remove the pad so he can work on the ding properly on both sides.
Old 05-09-2019, 02:43 PM
Len 911's Avatar
I used a dent guy and my car is black..amazing what they can do
Old 05-09-2019, 02:44 PM
ok great.
ill use a putty knife or something to get it off and then put some dynamat or something similar in its place when he is done
thanks
1983 911sc
Old 05-09-2019, 04:20 PM
