LinkBack | Thread Tools | Rate Thread |
Would a Leak in this Breather Hose Cause Low/Unstable Cold Idle on a 3.2 Carrera?
Would a leak in this Air Filter Housing to Oil Reservoir hose cause a low idle speed when starting engine cold? This is in an 84 3.2 Carrera.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F35 2327197942 Idle is fine when engine is warmed up. Idle is low only at cold start and is unstable. Evens out after a couple of minutes of engine running. Idle Control Valve has been cleaned and is working fine. |
| Tags |
| carrera , hose , leak , low idle |
