Need Help diagnosing no-spark
I'm working on getting the engine to fire on the 77 911. Car has been idle since mid-90s. Cap, rotor, wires, plugs and coil (MSD) have all been replaced. I've also quickly gone through the ground and fuse connections and cleaned those. Fuel lines and pump are also new. The car turns over freely.
I'm getting no spark, except sometimes a single spark when the key is turned to "on" position. No noise coming from the ignition box. Trying to determine of this is an issue with the Perma-tune 11-75 ignition, wiring or grounding. I'm not well versed in electrical. and in need of help. How do I determine if the Perma-tune unit is any good? Or if it's a wiring problem? |
Anyone?
A 3-pin box can be tested fairly simply; remove the 3-pin connector and run individual wires to it. Pin B (center) is +12 volts, Run a wire from pin A to the coil (the other side of the coil is GND) and then hook a wire to pin C. Connect a spark plug to the output wire of the coil via a high voltage cable and ground the spark plug.
Once you provide +12 volts to pin B of the box you should hear the 3kHz whining noise. Once you touch the wire from pin C to GND you should see a spark being generated.
Are you saying to leave the wires/ plug disconnected from the box? If so, this is to bypass the ignition box?
Yes - unplug the box. This is a test to see if the ignition box is working.
Do you still have points? Have you checked your points gap? |
Thanks! Will give it a try.
This is a 77, which I believe is the first year without points. |
77s are the last year with points. S model, 2.7L, green shroud.
That's what it is. I'm sure the points will need to be adjusted in this case. Obviously I had the cap off, but didnt recall what I saw in there.
On the other hand, I've gotten no spark on the inbound wire to the coil. |
That's good info! Thanks for the guidance. If that turns out to be the case, It would have taken me forever to find it on my own.
Hopefully I can steal some time to tear into it tomorrow and see what the situation is. |
Lots of threads on this topic. Do a search. Here is one thread that may be helpful.
http://forums.pelicanparts.com/porsche-911-technical-forum/449527-how-do-i-check-coil-timing-light.html Quote:
Points, check. Corrosion, check.http://forums.pelicanparts.com/uploa...1557797661.jpg
http://forums.pelicanparts.com/uploa...1557797661.jpg |
I've never seen a set of points looking quite like those! You should clean out that distributor, make sure you can turn the shaft by hand and have it spring back on its own, drop some oil down onto the wick down in the shaft, and reinstall some new points set to a 38 degree dwell.
What kind of oil should be used?
I would remove that distributor, carefully blocking the hole in the engine with a clean rag, and give it a good cleaning. If it looks corroded where you can see it, you can only imagine what is below the advance plate. I did this with mine and was amazed at how much crud came out the bottom. You do not necessarily need to disassemble it to clean it. Various cleaning sprays are available that you can direct into the cavity and watch the dirt flow out. You can check your work by seeing the action of the advance plate improve. You can also soak the entire unit in a container of solvent if you remove it from the engine.
That trigger wire going to the dist. looks like it's taped up. Does not look good.
I agree. They were actually both bare and touching. Hence the tape. When I get the chance to dig into this, unless I go ahead and buy the MSD ignition, there will be some rewiring in this area.
Check closely the connection at the dist where the post goes through the dist housing. Make sure the insulated parts are sound.
| All times are GMT -8. The time now is 05:14 PM. |
