Door moisture barriers
Hi I am getting ready to replace the missing plastic moisture barriers in the doors of my 1970 t. How does the door upholstery/hardware come apart and what would I fasten the plastic sheet to the door with? 3m adhesive spray? Any pitfalls to avoid?
"farking Porsche hero"
I use duct tape to attach the plastic to the door. Easy to put on, easy to remove, and reuse when a regulator pivot goes south. Plus, invariably, once I get a door all the way back together, I find an extra part and have to take the whole thing apart again. Last time, I forgot the driver's door plastic sheet, which has been sitting on my workbench since spring.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
As far as the weatherproof is concerned use a thick plastic sheet, cut to size, use spray adhesive just on the edges(4") then across the bottom and about 10" up the sides about use gaffer/duck tape. You'll need to make a hole in the sheet for the door pull rod, double up the plastic sheet here.
To check it's fully weatherproof sit inside with the door card removed and get someone to spray the outside with water. |
911Tfan,
Bob at APPBIZ has die cut moisture barriers for under $10.00. Our host may carry them. Perfect fit......... Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Retired Member
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Host has them...cheap, fit perfectly, all hole sin the right spot. I used 3M spray adhesive from body supply shop.
1988 Carrera Coupe |
Paradigm Short Shifter
+1
pelican has them. Sells them as a pair for something like 5 bucks or something silly like that. They are pre-cut with all of the necessary holesalready there. I highly recommend getting a set. I am gonna be installing them as soon as I re-install the speakers that I installed directly on the door. I want to make a spacer so that I can mount them on the outside of the door panel itself. And have a decent looking grill. Thanks michael |
Regis turd ab user
I personally don't and wouldn't use a "vapor barrier", trapping moisture and condensation within the door panel seems to be a bad idea considering the contents, mechanical and electrical.
David |
AutoBahned
the door is designed to use a vapor barrier & has weep holes at the bottom
Sherwood |
You guys are probably going to throw rocks at me for this...
There is a sticky product that is tar-like on one side and aluminum on the otherside. You get it at home improvement stores. It is in 4", 6" OR 8" width in a roll. It is used to seal up windows in buildings. I use it across the top edge and a few inches on the front and rear of the panel, leaving the bottom of the plastic panel completely open. It seals very well, is impervious to moisture and yet still easy to get off the door when you need to service it. With just a few inches on the forward and rear of the panel, break those lose, flip the plastic up as it is still adhered to the top, work on the door, drop it back down. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
I use the black caulking ribbon used to seal glass into thermal windows. I believe it's like the 3M black caulk strips sometimes referred to as Dum Dum (which it really isn't.) Like what Angela posted, it secures the vapor barrier yet allows for removal of all or part for access to the interior of the door and can be resealed as it stays sticky and pliable. It's what many newer cars use to secure the barrier to their doors.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I purchased a set of pre-cut moisture barrier plastic. I was wondering, why can't I stick the barrier to the door pad instead.
What's the cons to this idea ? |
New-ish 911SC Targa Owner
Most oe's use "dum-dum" to adhere the vapor barrier sheet to the doors.
![]() you set the plastic out on the table and put the dum-dum on it around the outside edge, leaving a little bit of plastic overhanging the dum-dum. THen transfer to the door. Viola!
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Proper way is to use 3M Windo-Weld Ribbon Sealer part #08610. Sold as a 1/4"x15' roll. I believe they also sell a flatter, wider product but the 1/4" should do the trick. Non hardening; remains sticky. Looks like that's what pampadori posted.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Been here a while
and, the proper moisture barrier has a second layer of plastic so you can tuck it into the holed in the inner door-skin, to direct water flow into the door drains, and still protect the hardboard door panel. A seal within a seal.
looking for 1972 911t motor XR584, S/N 6121622 |
Glue the barrier to the door.
I used a bead of 3M weatherstrip adhesive along the top of the top of the door/barrier. Used the old door card retainers to hold it in place until the glue dried. You still need to reach inside the door and tighten a nut that holds the armrest after the door card is in place so don't glue the barrier in at the bottom.
1973.5 911T ——-1974 914/1.8 Last edited by Artfrombama; 05-13-2019 at 07:49 PM.. |
I've always used a folded-over black trash bag with black duct tape. Not visible from the edges, and takes a few minutes to cut properly with scissors. I've had my doors apart a half-dozen times for various issues, so this strategy has saved me a lot of money.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Glue in a can works fine, which I used and have had no problems.
Serge |
The trick is to use something that allows you to pull the vapor barrier off later without destroying it. Glue will require you rip up the barrier next time you want to take it off. Use the 3M window stuff and you won't be looking around for more plastic the next time you have to get into the door cavity. The stuff stays pliable and sticky.
It's also great to hold screws and bolts in place on a screw driver or socket when working in difficult places where they're likely to fall off and get lost. I keep a bit of it in my toolbox and use it frequently to keep from losing fasteners.
