-   -   Ignition Harness Issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1029555-ignition-harness-issue.html)
Steam Driver 05-14-2019 04:50 PM
I am having an issue with installing a new ignition harness on my 911SC, which I am sure others have run into.
I am backdating the heating system to eliminate the blower in the engine compartment. I know lots of others have done this. The problem is that the Beru harness for the SC has straight connectors that go into the distributor cap. #2 and #6 are interfered with by the configuration of the new (old style) LH hot air spigot. #6 could possibly be made to plug in, but there is no way #2 will.
It appears to me (looking at the pictures in our host's catalog) that the harness for the later Carrera 3.2 has right angle connectors at the distributor and should work fine. Does anyone have any experience with this?
Trackrash 05-14-2019 05:55 PM
I'm not sure what you mean by "ignition harness". Post a picture.
timmy2 05-14-2019 08:30 PM
I’m guessing he means spark plug wires.
May need to adjust the clearance to the distributor on the duct as most need to do.
This has been posted in most backdate threads.
Flat6pac 05-15-2019 08:29 AM
You need to get the turbo tube for that side, it gives clearance for the plug wires and distributor cap.
Bruce
Steam Driver 05-18-2019 11:55 AM
To clarify, here are some pics of the area. I can't find where I ordered it, but can anyone identify the air socket part I have?
http://forums.pelicanparts.com/uploa...1558205733.JPG
timmy2 05-18-2019 12:26 PM
Likely you have one for a ‘73 or earlier. They need to be adjusted for the distributor cap and wires to clear by cutting and welding it, or by creating a depression in the area with a hammer.
(I used the hammer method)
timmy2 05-18-2019 12:32 PM
http://forums.pelicanparts.com/2412122-post22.html
Shows difference in original and one with clearance for dizzy.
A little extreme, (maybe needed for a 3.2 )
I didn’t need to make that much room on my 3.0.
Jonny H 05-18-2019 12:37 PM
I have the same part. Just reshaped it with a body hammer and repaint. You need good clearance with the HT leads or the spark will jump to the tin.
Trackrash 05-18-2019 03:29 PM
You can see where I modified mine. Some careful work with a hammer and dolly, some sanding and paint and you will be good to go.
http://forums.pelicanparts.com/uploa...1558218553.jpg
Steam Driver 05-18-2019 05:13 PM
OK guys, thanks.
