Case Savers in Magnesium case
Two of my transmission studs are not holding torque in my mag case. They spin about 20ft lbs.
I noticed this when removing nuts when replacing flywheel seal. Any ideas????
Old 05-17-2019, 02:36 AM
Loctite
Old 05-17-2019, 03:51 AM
Brew Master
cabmando's Avatar
Not saying mine would be the best solution but could you go up one thread size and tap new threads? From what I remember there's a bit of play in the holes for the transmission.
Nick
Old 05-17-2019, 04:05 AM
It's a 914 ...
stownsen914's Avatar
The problem is that the threads are damaged/stripped, or that the stud is turning in the case when you attach the trans and tighten the nuts?
Old 05-17-2019, 08:46 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
I seem to remember having heli coils in those threads on my old 2,2. That may be an option if there is enough good metal around the threads.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-17-2019, 11:07 AM
Case saver, 10x1.75, just like doing head studs
Bruce
Old 05-17-2019, 11:45 AM
Vintage Owner
Jack Stands's Avatar
Case savers would be the strongest alternative. Timeserts May be another, but I’ve seen Timeserts that have also pulled out of magnesium cases (tobe then replaced with Casesavers).
84 Targa
70 914-6
73 914-6 2.7 conversion (sold)
75 GMC Motorhome
Old 05-17-2019, 11:56 AM
I left out probably the most important part of my post.
I already had case savers installed 12 yrs ago. Case savers appear to have a larger insert which does not leave me with much room for error.
Iím not sure if loctite or JB Weld would hold 28/30 ft lbs.
Old 05-18-2019, 04:31 AM
It's a 914 ...
Blue Loctite should hold that torque. Worst case you can use the red stuff - just keep in mind that heat is typically needed to remove fasteners when you use red Loctite.
Old 05-18-2019, 04:43 AM
abit off center
cgarr's Avatar
A timecert should work fine in that area without the thermo expansion issue as with the heads
Craig
G2Performance
Old 05-19-2019, 05:50 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Happened on mine. Went casesaver and worked. Found the Mag cases get brittle over time and heat cycles.
CM
Old 05-20-2019, 11:17 AM
My problem may be case savers were already installed. The outside diameter is 12mm so the hole is pretty large.
Iím now waiting for new studs to test how well they hold torque.
One side looks ok but the opposite side appears to have rotated in which may continue to rotate inward.
Old 05-20-2019, 01:44 PM
Red locktite did not hold.
The case saver left about 13mm hole. I’m not sure if it’s enough of magnesium on the mounting ear to go larger.
Any suggestions
Old 05-30-2019, 02:28 PM
Old 05-30-2019, 03:08 PM
BNSMOE,
I’ve used JB Weld on my mag case with good results. Lasted about 10 years and still holding. It’s lasted through several engine removals where the fasteners are removed and then re-torqued.
I’d remove the old case saver and JB Weld in new case savers. Let us know if it works.
Rex
1975 911s and 2012 Range Rover Sport HSE
1962 BMW R50/2, 1995 BMW R1100RS
Old 05-30-2019, 06:17 PM
Originally Posted by Walter_Middie View Post
BNSMOE,
Iíve used JB Weld on my mag case with good results. Lasted about 10 years and still holding. Itís lasted through several engine removals where the fasteners are removed and then re-torqued.
Iíd remove the old case saver and JB Weld in new case savers. Let us know if it works.
That is what I was going to do.
I think JB Weld will fill in better than locktite
Old 05-31-2019, 07:49 AM
