Runnin on empty
acme911's Avatar
Will a ‘74 CDI work in a ‘79?
I'm helping out a friend. His ‘79 3.0 CDI has crapped out and I have one
from a ‘74 2.7. Can they be swapped?
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 05-18-2019, 03:45 PM
Under the radar
Trackrash's Avatar
No. The SC CDI is a 6 pin unit, as opposed to the 3 pin from the '74. The SC unit is triggered from a magnetic unit in the distributor where as the '74 uses points. Not to mention the fact that the wiring harness and associated ignition wiring are totally different.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-18-2019, 03:53 PM
Runnin on empty
acme911's Avatar
Thanks Trackrash! I’ll let my buddy know.
Old 05-18-2019, 04:21 PM
Armin
Trackrash is absolutely right. 3 pin vs 6 pin.
Old 05-18-2019, 05:01 PM
