Send a message via AIM to Adidas
Fuel Pump Recommendations
The fuel pump on my 1993 911/964 is getting louder. Not sure if the mileage on it but I'm going to replace it.Any other fuel pump options rather than Bosch that you have had good longevity with. Mine is a front mounted fuel pump.
Old 05-27-2019, 12:12 PM
Is it always loud, or just when the fuel level gets low? If only with low fuel level, it could be that the outlet screen is getting restricted and causing a pressure drop before the pump. or the fuel tank vent system could be blocked creating a low pressure in the tank. Does it sound like a vacuum pulling air in when you first open the fuel filler cap to refuel?
Old 05-28-2019, 06:26 AM
