Help! - Clewett Wires came with the wrong ends? Maybe?
So I ordered a set of Clewett wires for my 964 converted '75. They arrived and I am doing the install. Got the top half of the car wired up, went to install those wires on the new dizzy cap and discovered this? The ends of the wires are loose on the terminal that is sticking up from the dizzy. I could take pilers and close them down, if this is the right solution? However the boot it is not even touching the dizzy cap when the wire's end is all the way down onto the dizzy cap terminal.
Before I try something and mess things up, should I crimp down the ends, and try to slide the boots down farther? Or are these the wrong ends? ![]()
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles Last edited by Duc Hunter; 05-19-2019 at 12:28 PM.. |
Terminals are for earlier caps. The wires are wrong. Send them back.
Thanks dannobee. Not the news I wanted but that's ok. Thanks for there heads up. Pelican F's me again. Grrr
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
