Part Numbers?
Hi,
Does anyone have the part numbers for the following parts? I tried to order them from Pelican and wasn't able to describe them to the sales rep. --The black plastic plugs that help attach the rear targa bar seal (if I recall correctly there are 2 on each side, near the corners). The are more or less destroyed when you pop them out to remove the old seal. --The black plastic screws with the large flat heads on the front and to the side of the targa bar itself (2 on each side). Thanks. |
| All times are GMT -8. The time now is 02:41 PM. |
