Another no start issue
Hello all. Well, I was hoping to write an intro before having car troubles but not the case. I’m returning to the forum with my recently acquired 87 911 with 148k miles. I owned my first 87 911 cab for 7 years from 2007-14. This one is a coupe and has had a recent fuel tank replacement by PO, professionally installed. New fuel pump also was professionally installed after original one died about 2 weeks ago. Bought and drove car from OH to AR (also about 2 weeks ago) without a hiccup (except strong fuel smell when tank was filled to the brim—I think this is a separate issue but am open to suggestions). Last Sunday I took it out for a spirited drive, and it ran great. Stopped for a meal and came back out to head home. Car started and then sputtered and died. Tried several times to start it, and it would sputter some and die. Switched DME and just cranked with no sputter or anything. Had to flatbed the car home.
Here is what I’ve tried after consulting Bentley and several threads: —checked and confirmed good battery connections —confirmed spark with spare spark plug —confirmed a fuel delivery issue by car starting with starter fluid and then immediately dying. —removed DME relay and jumpered 30 and 87b to check functioning of fuel pump. I can hear a low thump (a little hard to describe) when tested but does not sound like what others describe when fuel pump is running (I just don’t remember what the fuel pump sounds like). After a short period, the fuel pump becomes very hot to the touch when jumpered. So where do I go next? Bentley says check fuel pump ground wire (brown wire) for continuity to ground but unsure how to do that. Could the fuel pump be bad, and how could I confirm this? Am I missing anything obvious? Thanks in advance. Sent from my iPhone using Tapatalk |
Low thump? Should be a soft hum. You might get a fuel pressure gauge to connect to the port back on the driver side fuel rail. The fuel smell when full is the nice thing about owning a cab! Gonna sound dumb but are you sure there's gas in it? The sending unit could be wrong.
Thanks for your response. Yeah, I remember that advantage of cabs... the only advantage maybe?!?! Haha
It has gas, confirmed by gauge and mileage driven. Definitely not a low hum with fuel pump. Ok, will look into checking fuel pressure. Sent from my iPhone using Tapatalk |
Another bit of data: it seems pump doesn’t respond the same with the key on as it does when i jumper 30 and 87b. So no thump when I turn the key on.
The fuel pump will not run with the key just turned on. It has to be in start/cranking mode. Then it's hard to hear it over the cranking engine.
You jump 30 and 87A to get the fuel pump to run. Might be different on an 87 but the SC's use 30 and 87A.
1 Attachment(s)
Thanks for confirming the fuel pump only runs while cranking.
In the pic of Bentley there is no 87a, only an 87b (sorry if that pic is inverted). Attachment 10503 Sent from my iPhone using Tapatalk |
My '85 3.2 fuel pump runs when ignition is ON. (Doesn't make sense that pump would only run when engine is cranking if cranking means turning the motor over to start it.)
Thumb means the pump has likely seized
If you jumper 30 to 87 and the pump doesn't run, but you hear a thump, it could be that something jammed up the impeller in the fuel pump. That would also explain the pump getting hot.
Agree, the pump has likely seized. It should not be getting particularly hot.
would the replacement tank happen to be a Dansk, i have had several problems with
there tanks taking out new pumps. i always use a pre pump filter now when using a new Dansk tank |
came to my mind... vacuum breather free?
Back on this issue. If the fuel pump was locked up causing heat, you should have popped the fuse. I would think the motor trying to turn the locked pump would draw more amperage (hence the heat) and pop the fuse. Without being there I can't say for sure but it doesn't seem like the pump is seized since the fuse didn't blow.
You can also jack up the front, drop off the skid plate, and check voltage at the fuel pump when the relay is jumpered (per instructions by others). If you don't see 12 volts, then their is an electrical problem.
If you do see 12 volts, you can pull the end of the fuel line to the fuel filter in the engine bay, and put it in a jar. Then jumper the relay again and see if you get fuel delivered by the pump. If you have voltage but no fuel, the pump is failed in some way. |
Thanks for all the comments, y’all. I’ll have to call the business in OH that installed the tank. From the receipt, it cost $475—would that make it a Dansk?
Also, I agree it should have blown the fuse if locked up, but the fuse is still good. I did check voltage at pump and got zero voltage, but I’m not sure I did it correctly. I jumpered 30-87b and put multimeter in both connections of pump—is that how to check voltage correctly (sorry, electricity confounds me)? @porschyard, I’d like to learn more about your pre-pump filter. Could you offer where you source your filter and maybe a pic of your finished product? Sent from my iPhone using Tapatalk |
In my experience seized pump will not blow the fuse. If you're getting a clunk when you apply power, that's all the testing you need.
Before you just throw another pump in there, I'd try to figure out why they're failing. Most likely debris in the tank. |
pre filter
I don't have any pics of that setup but i have been using a pre filter for many years even before the dansk fuel tank issues.I used them on cars that had been sitting and had fuel contamination issues.
Years ago i used a square plastic fuel filter for an audi, part # 811 201 511 D that worked fairly well, i have multiple crossover # for that filter but it has been NLA for years. what i liked about this filter was it was semi clear and you could see what it was catching. These days i use a napa 3299/ carquip 86299 and others and CUT THE HOSE BARB LIP OFF OF BOTH ENDS OF THE FILTER TO REDUCE THE LENGTH AS MUCH AS POSSIBLE . I butt the filter flush to the tank and the pump and connect with 2 short pieces of locally sourced 1/2 in fuel line and clamps. The whole assy. just barely is able to be fit and takes a little fiddling with to work but will definitely save a new pump from damage due to debris in the tank whether its a new tank or old. When i say just barely i mean JUST BARELY, the pump and cap nut assy will hit/rub on the return line fitting of the tank but this is possible, i have done it many times and saved alot of pumps. This is not a permanent install and i usually would revert back to stock after a period of time, usually the next oil change or service. I installed one of these filters in one of my 993's that was sitting in a used car lot for a couple years before i purchased it. There is alot more room in the 964/993 series fuel pump area and you can make a big loop with extended hoses and it works well. You can use the long hose loop method on a G series car but it gets very crowded quickly and hard to keep the hose from kinking. There has been previous discussion about the correlation between a new dansk tank and fuel pump failure if you do a search. At the price you stated i would say most likely it is a Dansk tank and i would not be suprised if thats what happened to your fuel pump. I have included a pic of a pump and filter so you get the general idea of what i have been doing, you want to keep the assy as short as possible. hope this helps out RICHARD http://forums.pelicanparts.com/uploa...1558462989.jpghttp://forums.pelicanparts.com/uploa...1558463340.jpg |
That NAPA 3299 is also the go-to filter between the gas tank and electric fuel pump on mechanically injected Alfa's. Inexpensive insurance for your 911 (or Alfa) fuel pump. Just one of those p/n's forever stuck in my mind. John
one more note, if i remember correctly the micron count on these filters is something like 32 or something in that area, basically a ROCK stopper
Much appreciated Richard and jjeffries.
Called the installing shop (in OH and I’m in AR). They confirmed it’s a Dansk fuel tank, and they recognize the need for a filter between the tank and pump but the PO didn’t elect to have it put in. Thankfully, they are working with me see if they can help with a replacement. Standing by... Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 02:23 AM. |
