New-ish 911SC Targa Owner
pampadori's Avatar
picture request - how much clearance from pulley to fan housing?
Would anyone be able to share a picture or two clearly showing how much clearance you have between your fan housing and the crank pulley? Mine seems extremely tight and i think I might want to loosen the band and see if i can wiggle it back some.
'83 Targa 300k w/ freshened 3.0 with 930/52 case and ARP and Raceware hardware - AEM Infinity 506, Triumph T595 throttle bodies, B&B headers, Dynomax muff, Fidanza FW, Alum PP
'05 E500 wagon in minty cond
'13 Volvo XC60 (hers)
Old 05-21-2019, 09:11 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
The SCs are seriously close.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-21-2019, 09:39 AM
Mine is feeler gauge tight; barely can see light between it.
Rutager West
Old 05-21-2019, 12:36 PM
I'm interested to hear more about this. My belt keeps hitting the face of my fan under heavy throttle and cant seem to get it tilted back far enough. But to answer the OPs question: Mine is super close to the pulley on an 87 3.2
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car
Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle
Instagram: @pdklol
Old 05-21-2019, 12:42 PM
Here’s a photo of mine. It probably has a 3/16th’s inch gap. Given that the fan housing sits on a dowel rod (peg), if your not seeing a gap similar to mine your housing is not likely positioned correctly on the peg. Just loosen the strap and wiggle and jiggle it until it seats itself on the peg.
Regards,
David Yerkes
1987 911 Targa - GP White
Old 05-21-2019, 12:50 PM
Flojo's Avatar
the fan Rotors should not touch the shroud at any spot!
if ist rubbing at bottom like in last picture, I guess the fan is slightly tilted, so there must be some obvious gap at top(?).
take off the fan belt, take out fanshroud with fan an check the seating of the fan/alternator within the shroud.
something for sure has come out of alignment.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 05-22-2019, 03:06 AM
Many housings are notched at the pulley for clearance
Bruve
Old 05-22-2019, 03:40 AM
Looking closely at your photo, there appears to be more than enough clearance. Mine also was very close but it wasnt touching.
Old 05-22-2019, 04:15 AM
Floco - the scraping occurred on the first startup following having the fan and housing refinished (ouch!). It was a result of having overly tightened the strap. After correctly torquing the strap there was no further contact between fan and housing.
Please note that the photo I provided was to show the gap of the housing and pulley to the original post, but I guess doing so leaves me wide open to my mistakes.
Regards,
Old 05-22-2019, 04:28 AM
pampadori's Avatar
Just a couple of things:
Tracktrash's photo doesn't have the strap installed. Probably not a great example but it still does look pretty close. The 3.2 seems to have more of a gap than the few SC pictures I've seen.
Mine, like RWest is very close. Probably .020" or less even.
It does appear that mine is out towards the rear of the car a little more than it should be. I'll loosen my strap and readjust.
Thanks for everyone who replied!
Old 05-22-2019, 06:19 AM
