79 head stud repair
Have a 79sc and just found out #6 head stud is broken.
Car has only 48,000 miles. Do I do head stud repair only, top end or complete rebuild.
My thinking is top end. Car seems to run fine but would like to keep it going forward.
IS 40 yearss old with no previous engine work.
What should a top end cost compared to complete? Original stock car. Thanks for any input.
Old 05-22-2019, 07:07 AM
jamesjedi's Avatar
There are many threads on this. Top end only - is of course cheaper. The thought is that you are most of the way there for the bottom end. 48,000 may not have bottom end issues, but it may leak after 40 years.
Old 05-22-2019, 07:53 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
You might want to tell us your location. And how much, if any, work you plan on doing yourself. Prices have been quoted from ~$4k to $20k for a shop to do all the work.
Search here and in the 911 Engine Rebuilding Forum and you will find lots of info.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-22-2019, 08:39 AM
Being that it needs to come down for stud replacement, disassemble all the heads and see how the guides feel. That top end job will reseal from the case outward. Do the case halves seep enough to worry about?
206 637 4071
Old 05-22-2019, 09:08 AM
Thanks I'll check out other threads. , I am in central Virginia. Will not being doing any work myself.
Car seems very dry on bottom and uses very little oil.
Never see any drips when parked.
Old 05-22-2019, 09:19 AM
fred cook's Avatar
Rather than just replacing the one broken stud (probably one of the bottom Dilivar studs), replace all of the bottom studs with steel ones. The Dilivar studs can be identified with a magnet as they are not magnetic. Broken Dilivar studs on these engines is a common issue. I would have the heads done while they are off, replace the studs and fix any small leaks you find. The rest should be ok.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-22-2019, 09:22 AM
Two years ago the broken head stud demons came into our '75 911S. $16.k later she runs well not including opening the case.
Sorry to hear of your misfortune.
Yes, many threads exist and if you are handy with a wrench give it a try yourself
Old 05-22-2019, 03:23 PM
jamesjedi's Avatar
The broken studs will be the lower diliver studs. Steel uppers would most like be fine. If you don’t have the budget to do a full rebuild - replace all studs with new steel studs and have the heads rebuilt. Replace the gaskets.
I would be curious if anyone has seen a broken steel stud? Perhaps race engines with high power?
Old 05-22-2019, 04:47 PM
Red Line Service
Marc Bixen's Avatar
Boy, you guys need to do some homework on studs. Sounds like your trying to make more work for the few good engine builders still around.
Marc Bixen
Red Line Service
West Los Angeles, Ca.
www.redlineservice.net
info@redlineservice.net
Old 05-22-2019, 04:58 PM
Under the radar
Trackrash's Avatar
Are you offering your services? Give the OP a quote.
He stated he is not doing any work himself.
Perhaps there is a shop near him that will do the work for reasonable $. Perhaps someone will chime in about that.
Gordon
Old 05-22-2019, 05:25 PM
otto_kretschmer's Avatar
first thing I would do is a leak down on all cylinders
if the engine is tight, I would take one head apart and inspect the guides and valves
if the guides and valve on that one head (#6 since you gotta take it off anyway) are good I would just replace the studs and put the engine back together
its still going to be pricey since you are having someone else do it but that can't be helped
old cars are a gamble any way you look at them and if you want to keep everything like it just rolled out of the factory its going to have to be in the Jay Leno league
Old 05-22-2019, 06:19 PM
one more bit
if a leak down for all cylinders are good, like 94 psi down stream and 100 psi upstream of the orifice, and you have good oil pressure then your engine is in good condition
Old 05-22-2019, 06:42 PM
I drove my '79 with 4 broken head studs for several years before having a top end rebuild ... yes, shameful of me ... drove about 1.5K miles/yr.
Total cost was about $16K (Long Island), but included SSI's, up-graded chain tensioners.
Jason
'79 911SC Targa
Old 05-23-2019, 05:02 AM
Thanks for all the input.
I will probably drive it for a while longer.
Seems to drive fine ....at the moment.
Small monthly jaunts, nothing long.
Buying a new piggy bank today! haha
Old 05-23-2019, 07:25 AM
