72' 911S
leadrsa729's Avatar
Send a message via Yahoo to leadrsa729
Fuel Pump Replacement
Hi All -
I've got a 72' 911 that i had converted to carbs a while back. The fuel pump has given up the ghost. I had the setup from PMO where you can regulate the pressure by adjusting a valve on the return line. What pump would be the best replacement without having to purchase the original one which is over $800, and would require minimal modification?
Thanks for all your help!
Old 05-24-2019, 01:41 PM
digitaldgp's Avatar
I just had my 1970 911T carburetor Bosch 3 port, fuel pump rebuilt by "Fuel Injection Corporation, 2246 n. MacArthur Dr. Tracy, CA 95376" It was $395 plus shipping. They can turn it around in a little over a week, and it looks great! https://fuelinjectioncorp.com
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 05-25-2019, 05:33 AM
Many specialized Bosch pumps are far more expensive than mainstream pumps, simply because of the volume they're produced in. Bosch started rationalizing their fuel pumps over 10 years ago via the "universal fuel pump program"; they starting making pumps they never sold NLA and suggesting alternatives.
Which is probably why you're being quoted $800 for one they don't make anymore. Unless you absolutely want/need originality to go with 60 year old tires and the original spare fan belt, I'd just opt for a cheaper pump that's better.
I fitted a Bosch 044 motorsport pump, paid $200 for it 12 years ago. They're cheaper now...
They're comparatively cheap because they're widely used and produced in huge numbers - on everything from GT3s, Cosworths, WRC cars, tuner cars etc). Very high performance & capable of supporting much higher flows/pressures than any pump Porsche fitted back in the day.
There was a rash of obviously-fake Chinese counterfeits at one time; easiest to just buy from a reputable source if you can't be bothered or can't tell the difference (youtube videos telling you how to detect them - really, really obvious).
You'd have to adapt electrical connections (both go up a size bigger).
Use a higher-rated fuse maybe (don't know what your stock fuse is); Bosch quote max current @ 13A, IIRC - but they don't draw that much on a ~400 RWHP CIS 930 requiring 6 bar system pressure... Mine ran perfectly happily on the same 10A fuse for over a decade until I upgraded to the ClassicRetrofit fuse panel.
The fuel pump has an 18mm outlet. Adapters widely available.
They're physically a little longer; my car had plenty of room on the cross-member where the factory pump was.
'77 S with '78 930 power and a few other things.
Old 05-25-2019, 08:25 AM
BoxsterGT's Avatar
Porsche Crest
Here is what the Bosch 044 pump looks like with adapters for the 911 stock replacement.....
However, not necessarily the way to go for a 72 911, as pump pressures are controlled externally. I have heard that the PMO regulator restricts this big pump too much. Hopefully someone w first hand knowledge will add the info needed.
Len
Old 05-25-2019, 10:53 AM
Can you guys direct me to the specific adapters needed to replace the stock unit in my '87 Carrera with this "044" pump? Sorry to hijack; TIA.
Lyle.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler
'07 Boxter
Old 05-28-2019, 09:13 AM
BoxsterGT's Avatar
Porsche Crest
I have them and happy to help........
Len.Cummings at Verizon.net
Old 05-28-2019, 09:35 AM
Thanks Len! Will send an email...
'07 Boxter
Old 05-28-2019, 09:44 AM
Grady Clay had some thoughts on running a CIS high-pressure pump on carbs with the PMO bypass regulator in this thread: PMO Carb's using MFI Fuel Pump - Issues?
Old 06-03-2019, 04:45 PM
