Scratched Sunroof
Just opened my sunroof on my 80SC and it scratched it😡 it was kinda off track it seems had to push up on it from the inside to get it to close. Any ideas?
Reiver
Delete it and save the weight....
De Oppresso Liber Strength and Honor 5th Legion |
you have to partly open it ..slide away the headliner..to access the cables and brackets.Unzip the back headliner and remove the motor...This way you can then manually slide back the sunroof.You know you have to paint it right?
Also use search button up in corner there is plenty of guide how to go about it.. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Hopefully, hopefully... It's just the clearcoat scratched. You can test the paint by putting water on it. If the scrtach dissapears a clearcoat touchup can fix it.
In regard to the sunroff it's self
Slippery Slope Expert
I think the real issue here is “what scratched it to begin with?”
I think I would start by hand cranking the roof back slowly so I could see what was happening. In lieu of hand cranking you could also remove the motor and slowly slide it. But in any case the cause of the problem needs to be found first. I have had mine apart and don’t remember anything that would make scratches like that, but obviously there is. PM me your e-mail and I will send you a write-up I have on sunroof mechanics. It will be via Dropbox; too large for an attachment. I know there are a lot of sunroof haters out there, but personally I like them. A nice European touch. Weight not an issue unless it’s a track car. You can get part of that elsewhere, for example by removing those useless rear seats!
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” Last edited by Steam Driver; 05-24-2019 at 03:33 AM.. Reason: Sunroof hater addition |
The panel will need to be removed to refinish it. But to do that it will need to be partially opened.
See the shop manual, and I will also send you the link to my PDF tonight.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
Banned but not out, yet..
Whatever you do, do not completely remove the little screws on the back pieces that resemble little interlocking teeth. Removing those screws are not necessary to remove the roof, they are used for adjusting the back of the roofs height. If you do remove them bring a big bag of patients to get them back in. Sorry no pictures of the abominations.
An air cooled refrigerator. ‘Mein Teil’ |
