901 Transmission
Hi All, I'm restoring a -71T which I bought in crates. This is the transmission I got. There are some flat areas at the bottom front of the case. They both have two holes in them.
What is this for? Is my transmission case modified? Please help shed some light over this! Jörgen Forssling Gothenburg SWEDEN ![]() ![]()
HI Jörgen
the gearbox looks like it has been fitted to a VW Beetle, as the Rev light switch has been chopped, and there are large studs in the end casing. is the speedo drive still in the end case? the holes in the bellhousing are to mount the box in the beetle gearbox support. I would remove the drive shaft flanges from the box and take off the diff side plate, to inspect the pinion, also remove the end case and inspect 1st gear dog teeth regards mike |
Thanks Mike, for your input.
The speedo gear are still in. Can you clarify "there are large studs in the end casing" and "Rev light switch has been chopped". So if I weld the holes for the beetle gearbox support I will be OK with this case you think? Is it aluminium or magnesium? Will get back regarding inspection when I clean it up some more. Thanks a bunch! //Jörgen |
Under the radar
The case is magnesium. The clutch release arm and cable are unique to this trans.
Post a picture of the other side of the trans and inside the clutch area. If you plan on using the '70-'71 clutch, cable, and other parts you will need to have the three parts shown by the arrows. ![]()
HI Jörgen
the Rev light switch should look like this ![]() and the end case, like this, ![]() this is the casing with no holes, it is from a 914, converted to fit a 911 ![]() the case is magnesium, 911/01 box should have a gear set of ; 1st A 11:34 2nd GA 18:32 3rd O 23:28 4th V 27:25 5th ZA 29:22 with a 7:31 CWP unless some one has been in there and changed things round has the clutch arm pivot in the bell-housing been moved/changed, as some times the ratio is not correct for the Beetle and the clutch will not work correctly regards mike |
Thanks Gordon and Mike for valuable info!
I will check my trans and get additional photos when I get home. Meanwhile, can I ask you Gordon about your pic with the arrows: Top arrow, is that a separate part or integrated to the diff cover? Bottom arrow, same there, a separate part or integrated to the case? I have searched for images but find very few with these details. Can't seem to find these details in the PET either. Can you post some additional images? KR//Jörgen |
Puny Bird
I agree it was in a bug, I have a 911/901 with 914/4 gears in my '67 bug with a 2.6L T4 engine.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Hi All!
I got some additional photos yesterday. I have now seen that the both parts I'm missing is integrated. My plan is, for the case, fabricate a mount in aluminium and bolt it using the two existing holes. Weld the two holes on the other side. Try to locate a diff cover with the cable guide intact. Or fabricate it and use the bolt below to fasten it. I need to find a drawing of the bell housing or find someone to stencil the clutch wire fixture. Anyone here that can help? Regarding the gears, is there a way to determine what gears I have shifting gears and count revolutions? ps. I've got the clutch fork. The yellow bolt just put there temporarily. Thanks for all your support! //Jörgen ![]() ![]() |
Under the radar
Looks like you can make it work. Unfortunately my 901 is long gone, but hopefully someone will chime in with the measurements you need.
If you get the clutch cable with the end pieces that will help you get things aligned correctly. Thankfully the release arm pivot mount is still good.
Thanks Gordon! These days you've got to work with what you have. I have a new cable and end piece so that will help as you say.
What do you think about finding out what gears I have? Got any ideas on that? Cheers//Jörgen |
Under the radar
Have you pulled off the side plate yet to inspect the ring and pinion? I would do that before commiting to this trans. Not hard to do, and if the R&P is good, most likely the trans is usable.
As far as the ratios go, I would guess they are the stock 911 gears. Who would change the gears for a VW? But who knows. 1st A 11:34 2nd GA 18:32 3rd O 23:28 4th V 27:25 5th ZA 29:22 You should try to keep your side plate. If you replace it with one from another trans you will have to check and posslby reset your R&P, which is a PIA. You will also need the cable guide (clamp) and the throttle crank. Here is a picture.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-23-2019 at 08:52 AM.. |
Gordon, I've got the throttle crank but not the cable guide yet. It is a hard to find item and NLA from Porsche.
OK, so I pull the side plate and there is the ring and pinion. What do I look for? Obvious damage? Something else? Appreciate you taking your time to educate me. //Jörgen |
Under the radar
I imagine it would not be hard to fab a cable guide, if you can't find one.
Here is a thread showing a damaged pinion gear. Metal bits in 915 oil You might want to take some pictures of yours and post it here if you have doubts as to its condition.
Ken Wunsche
901 Transmission
Attached is a picture of a clutch cable guide that bolts to the side cover. Another picture shows the welding jig used to align the parts. I can send you a guide for €50 including shipping to Portugal but you need to work through a complete solution first.
You have another problem though in that the clutch cable fixed point has been sawed off. Your clutch won't work without it. See the pictures. ![]() ![]() ![]()
Puny Bird
![]() My 3.0 914/6 (again conversion) has a,f,o,x and a flipped HB 5th. Only way to really know is to remove the stack.
AutoBahned
or spin things in each gear & count the turns...
BTW, the 1970-71 cars take a typ 911 trans, not really a 901 |
//Jörgen |
Puny Bird
![]() Nit picking and I do it for clarity. Really don't care, I've rebuilt way more than you have and I'll still call it a 911/901. 901, 914, 911 are all base 901 transmissions and 96% of the part # start with 901.
AutoBahned
not "Nit picking " if you need to ID something to someone else
but I'm sorry to hear about your parasite infestation |
gearhead
Put a 901 clutch in a 911 and you’ll care. Or order a 901 lsd for your 911 box and wonder why the bearings and axle flanges don’t fit. I’ve learned not to correct every single post here about it being wrong. However when someone says ,”how do I fit this 901 in my car?” It is importsnt that they understand the differences.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
