-   -   This is what happens when you have ADD (http://forums.pelicanparts.com/porsche-911-technical-forum/1030598-what-happens-when-you-have-add.html)
Sebscst 05-26-2019 12:43 PM
Well in the process of wiring in new distributor I rerouted the wires with a common theme.
http://forums.pelicanparts.com/uploa...1558899726.jpg
http://forums.pelicanparts.com/uploa...1558899775.jpg
RSBob 05-26-2019 01:30 PM
ADD or OCD?
Sebscst 05-26-2019 01:32 PM
Unfortunately both I’m doing 5 different things at once and all have to be perfect
RSBob 05-26-2019 08:52 PM
Ocd
Jonny042 05-27-2019 07:04 AM
ADD, OCD, and Schizophrenia?:)
RDM 05-27-2019 03:40 PM
The man is a mess, however you label it!
winders 05-27-2019 03:44 PM
I see no reason to not route the right side spark plug wires over the fan strap.....and one reason to not do what was done here. Those wires will be an issue when the engine is removed from the car.
Dkennel 05-27-2019 04:39 PM
I agree, my OCD would make me go in and route the wires correctly the way tjenPorsche engineers designed it and have them at the correct length. Seems like a fix for a non existing problem and does not look right to me, but may be more a question of taste...
Sebscst 05-27-2019 04:48 PM
Did not want to route them over the fan strap or the way Porsche did it . How will it be an issue when removing the motor? They are actually the correct length to route over the fan but why cover the fan strap.
AG81 05-27-2019 05:07 PM
This was totally a personal choice/taste issue.....I don't see any issue with removing the engine.....I don't do my mod's based on ease of engine removal......
93nav 05-29-2019 12:09 AM
I would need pics of the rest of the car to determine if your routing of the plug wires was correct or not.
shawn908 05-29-2019 04:01 AM
...perfect
OP - nice work. Original.
7783911 05-29-2019 05:55 AM
I like the look,,,very clean
I am OCD as well :-)
winders 05-29-2019 11:06 AM
God forbid doing what Porsche did. It must be somehow a flawed choice on their part. Let's be different just to be different.
Having those wires flopping around so they can snag on something is the problem. You really want them in a place they are out of the way.
Also, it looks like those wires are not fully captured by whatever retainers you are using. If one comes loose it will be sucked in toward the fan belt which will saw through the wire in no time.
But hey, it is your car so you should do what you think is best!
wayner 05-29-2019 11:21 AM
I like mine better :-)
http://forums.pelicanparts.com/uploa...1481075826.jpg
Sebscst 05-29-2019 01:31 PM
Winders please enlighten me as to how any of the wires will come loose as they are all held down by wire separators that are all mounted to sheet metal. Nothing can move. Also nothing against doing it “Porsche’s” way. Just wanted something different to set my car apart.
Hey Warner you’re giving me anxiety looking at those wires,but hey at least they’re for a twin plug:D
Bob Kontak 05-29-2019 01:37 PM
Not quite getting the flopping thing either.
Sebscst 05-29-2019 02:01 PM
Rest off the engine bay.
http://forums.pelicanparts.com/uploa...1559163458.jpg
And definitely not a stock front boot.
http://forums.pelicanparts.com/uploa...1559163660.jpg
wayner 05-29-2019 03:42 PM
Hey Wayner you’re giving me anxiety looking at those wires,but hey at least they’re for a twin plug:D
Ok, I'll send this pic to sooth you :-)
http://forums.pelicanparts.com/uploa...1481218761.jpg
tirwin 05-29-2019 03:52 PM
I have CDO. It’s sort of like OCD but the letters have to be in alphabetical order.
winders 05-29-2019 07:37 PM
Excuse the mess on the back left:
http://forums.pelicanparts.com/uploa...1559183852.JPG
