grateful user
don gilbert's Avatar
Inner turbo tie rod sticktion.
Hey guys, changing out my outer turbo tie rod end today and noticed that when i disconnected it from the knuckle, I have a lot of "sticktion" on the inner part. Is this normal? Takes some effort to get it to pivot around on the spherical bearing.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 08-09-2019, 02:39 PM
Pelican Parts Vendor
UROParts's Avatar
Stiction is a good thing when it comes to tie rods and ball joints; it means the joint is still tight and ready for use. If the joint moves without any resistance, it's worn enough to consider replacement. If it has detectable play between the ball and socket, it's really worn and needs immediate replacement.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 08-09-2019, 02:53 PM
