Where should I lift my Porsche??
Hi Guys!
I started to convert my side rocker panels to 964 Turbo, then my original lifting place dont be able to use. So where can I lift it up?? Pic on my original side rocker panels, that I canīt use: Thanks Jocke
Jocke Andersson Reach me on ICQ - 317860713 Porsche 930 -77 SOLD Modified, one of a kind in Sweden. Check out my car @: http://members.cardomain.com/jocke |
Crusty Conservative
Jocke,
Can you obtain one of the lifting plate adapters that are sold by PP & others? It will be a good solution for home use. On the road you may want to get a scissor jack???
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Crusty Conservative
/J
Crusty Conservative
Jocke,
Then perhaps you can place a scissor jack at the SAME position as the jackpoint was, only farther inboard, so as to avoid crushing your new rocker boxes....
Can't you lift from the bottom of the motor? I can on my 3.2.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Jocke,
Bill is right, I had the same issue since I also did a C2-Turbo conversion on my 1975. The best way is to get a newer jack (scissor jack) off a C2. I bought one on Ebay for $10.00 and if you modify the top part a little (that round area of the jack), then you can safely use it with your car. Later, |
Allright, thank you guys!
I go for a newer jack from a C2. /J
