piscator's Avatar
Quick AC Wiring Question
Reinstalling my AC and doing the variable fan upgrade from our host's tech section, here:
www.pelicanparts.com/techarticles/911_ac_switch/911_ac_switch.htm
I'd appreciate if someone could confirm what I think to be correct. That is,
Terminal #30 on the relay in the smuggler's box receives power from the red/white wire at the fuse panel (fuse 20A?) -- Yes? If so, terminal #86 on the relay should have 12v when the ignition switch is turned on -- Yes? If so, I think I have a bad relay.
I'm having some elder-confusion over how and from where power gets to the thermostat switch and the fan switch.
Robert
"A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe)
Old 06-13-2019, 05:40 PM
steely's Avatar
Can you post your year?
The pwr term' 30 on my ('87) smugglers box relay is Red, the Red/White went to the switch.
And I'm with you there on the elder thing brother. ;-)
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-14-2019, 10:29 AM
From the Bentley manual power comes of Fuse 2 of Box 3, 25A fuse via red wire.
piscator's Avatar
Thanks very much guys. I got it! There's now power to the compressor and the evap blower is working beautifully!
I did the modification pretty much as described in the pelican article. I wanted to use an on/off potentiometer instead of a separate switch; but the switch contacts on the ones I found didn't look substantial enough to handle the circuits 25 amp max. The lighted switch I used is rated for 20amps, so I'll keep an eye on it.
Appreciate your posting!
Robert
Old 06-14-2019, 02:59 PM
