LinkBack | Thread Tools | Rate Thread |
Help with Blue/White Stripe Mystery Wire Behind Gauges on 1988 911
I promise I went completely through all the wiring diagrams in my Bentley Service Manual before posting this.
I pulled the gauges to install Carmagic's LED set. While I had the gauges out I took a look at all the wiring and connections. I found a blue wire with a white stripe that appears to have pulled out of its connector because it has about an 1/8" of bare wire. I've been searching for hours. I can't find what this wire was connected to. It has no power. Not with the key in the off, accessory, on or with the headlights turned on. The wire comes out of the large bundle of wires of wires that runs underneath all the gauge wires. I have attached pictures. One of the blue wire with the white stripe and the other of where this wire exists the large bundle. I'm hoping one of you can solve this mystery for me so I can put my gauges back in. Sincerely, Dall Last edited by 1989Carrera; 05-28-2019 at 02:04 PM.. Reason: Pictures did not post. |
Under the radar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
High beam indicator?
ROW '78 911 Targa
Should be, if the same as earlier SC wiring and all earlier cars..
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI. Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. |
I'll go see if it's the high beam indicator.
My high beam indicator wire is white with a blue stripe. Any other suggestions? |
does your CASIS upshift indicator light (orange arrow in tach) work? Can't remember what color my wire was, but one can disable it by snipping/removing a wire that feeds into the tach wiring harness.
ROW '78 911 Targa
Turn signals working correctly? (At the gauge)
I honestly don't remember is that works or not. I'll go check. Thank you for the suggestion. |
Yes, the turn signal indicators work. Hazard indicators work. Hi beam indicator works. All the gauge lights are working. All the gauges are working. I'm going to check the shift indicator light. Thank you for the suggestion. |
Rescuer of old cars
I think the shift indicator is a black wire.
Only blue/white I can find on my diagrams goes to the fog light switch.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s 1972 911T coupe Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 05-28-2019 at 05:21 PM.. |
ROW '78 911 Targa
This is why I don’t build wiring harnesses newer than ‘83. Porsche changed way too many standard wire color combinations and their destinations compared to everything they built before. Along with most of the plastic connectors that are NLA. Never mind the downsizing of the wire gauge to thinner cheaper wires. The factory B&W prints suck too....
Maybe in a few years when I retire from my day job and have time to R&D them, but until then I will continue to avoid them.
Seeing this now. Think I read somewhere else this is the Euro tow- hitch pigtail? Not joking. John
Mystery Blue Wire with White Stripe
Burnin' Rubber
Rear fog light
---------------------------- '84 911 '95 840Ci ---------------------------- |
Caveman Hammer Mechanic
Whew,
Did the heavy lifting for ya, The entire thread explains that mystery wire, or go to post 10 or so. LED conversion
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Glad it helped!
Thread Tools | |
Rate This Thread | |
