ID 2 piece oil drain tubes (factory?)
Can anybody tell for sure from these pictures what kind of drain tubes these are? (Factory or what type of aftermarket)
Some are leaking between the two pieces so I was hoping the o-rings between the two pieces were available. Thanks
Brian Boss '71 914-6 2.2 MFI ............. '06 Lotus Elise '71 911T (fake S) ............. '64 MGB |
check our great host, they've got them. And no those aren't factory as far as I know. I replaced mine recently. It's not that hard to do.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Friend of Warren
aftermarket (although pelican calls them OEM), steel, expandable, sold by Pelican, among others. Here are the inner and out seals you need for them:
OEM Outer Oil Return Tube Seal (sold per each, 2 req. per return tube), 911/911 Turbo (1974-89) [Photo] [Photo] K-701-465-40 $1.60 Inner Seal for OEM Expandable Oil Return Tubes Only (sold per each, 2 req. per return tube) K-701-470-40 $1.60
Kurt V No more Porsches, but a revolving number of motorcycles. Last edited by Rot 911; 03-20-2003 at 11:00 AM.. |
they look like aluminum. OEM replacements are gold colored steel, with a lip that faces the snap ring, that appears to be missing in the pic.
what leak? fix one get three more. just kidding.
be glad there isn't a pushrod in the tube. john has specified a specific grease/paste/glue on previous threads on tube replacement. search or ask again
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Leaking? I guess you cleaned them up for the picture.
Well, I checked the tubes with a magnet and they do appear to be aluminum. Will the o-rings that Kurt gave the part number for still work? Should I just replace the tubes?
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
