ID 2 piece oil drain tubes (factory?)
Can anybody tell for sure from these pictures what kind of drain tubes these are? (Factory or what type of aftermarket)
Some are leaking between the two pieces so I was hoping the o-rings between the two pieces were available.
Brian Boss
'71 914-6 2.2 MFI ............. '06 Lotus Elise
'71 911T (fake S) ............. '64 MGB
Old 03-20-2003, 09:47 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
check our great host, they've got them. And no those aren't factory as far as I know. I replaced mine recently. It's not that hard to do.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-20-2003, 09:49 AM
Friend of Warren
aftermarket (although pelican calls them OEM), steel, expandable, sold by Pelican, among others. Here are the inner and out seals you need for them:
OEM Outer Oil Return Tube Seal (sold per each, 2 req. per return tube), 911/911 Turbo (1974-89) [Photo] [Photo]
K-701-465-40 $1.60
Inner Seal for OEM Expandable Oil Return Tubes Only (sold per each, 2 req. per return tube)
K-701-470-40 $1.60
Kurt V
Old 03-20-2003, 09:56 AM
they look like aluminum. OEM replacements are gold colored steel, with a lip that faces the snap ring, that appears to be missing in the pic.
206 637 4071
Old 03-20-2003, 10:18 AM
what leak? fix one get three more. just kidding.
be glad there isn't a pushrod in the tube.
john has specified a specific grease/paste/glue on previous threads on tube replacement. search or ask again
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-20-2003, 11:15 AM
VincentVega's Avatar
Leaking? I guess you cleaned them up for the picture.
Old 03-20-2003, 12:44 PM
Well, I checked the tubes with a magnet and they do appear to be aluminum. Will the o-rings that Kurt gave the part number for still work? Should I just replace the tubes?
Brian Boss
Old 03-21-2003, 08:44 AM
Friend of Warren
I've had the aluminum ones and have not been happy with them. These parts numbers I gave you are NOT seals for aluminum tubes. I would just spend the $100 and get the expandable steel tubes.
Kurt V
Old 03-21-2003, 10:13 AM
