-   -   Throttle position switch (http://forums.pelicanparts.com/porsche-911-technical-forum/1030928-throttle-position-switch.html)
kevstens 05-30-2019 07:03 PM
I was checking the adjustments of the switches on my 87 3.2 and found I got continuity at half throttle on the throttle position switch (WOT). I loosened the adjustment screws and moved the switch. It made no difference. I then adjusted the switch full travel in both directions and still got continuity at half throttle. If I close the throttle to less than half I lose continuity. The switch seems to be fairly simple. Has anyone seen this before?
winders 05-30-2019 07:39 PM
Measure the resistance...it’s a potentiometer.
steely 05-30-2019 07:58 PM
It's just a switch - with continuity around 75%.
kevstens 05-30-2019 08:24 PM
I was going by the Bentley manual. It says the switch makes when the throttle is wide open. The manual said when the switch makes, it sends a signal to the DME to increase fuel enrichment. My concern is at part throttle it is increasing fuel flow to early.
winders 05-30-2019 08:58 PM
Really? Just a switch? No wonder DME is so bad.....
