Glasurit or ??
I'm respraying my 68 911 in Chalk. Its a home slash borrow a booth job. At 140 USD a litre just for the r22 ( add hardner and reducer ). Its not a bare metal job as well. I'm doing it properly done with the car pulled apart. Its just a driver that I will use on weekends. Using Glasurit I'm up for a 1k USD for my paint and some primer. That's not using there 2k primer. ( add another 300 USD).
Is it worth using. ??? I'm happy to spend it if so. I can get a run of the mill 2 pack single stage for about 60 percent less. Thoughts of those who have been down this road. Thanks Lyndon
Cars and Cappuccino
Glasurit is good, no debate there. Consider Lesanol. It's pretty good too.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
I'm no expert. I learn off you guys.
But I have been using PPG products because they have very good information about what works with what. And seem to have everything. |
Lesanol is 30 percent cheaper. I will look into it.
Lyndon |
It’s more about the quality of the line you choose not the brand. Glasurit 22-line is the top of the line single stage paint from BASF. You can go cheaper within the BASF family of paints or you can go to other paint brands. Lesanol is an Akzo Nobel product. Decent. Just don’t skimp to the point you end up with crappy paint as there’s some cheap stuff out there
Advice in the Paint and Bodywork Forum, Glasurit 22 is highly recommended.
Glasurit 22 vs PPG DCC
Ed 1973.5 T |
Fleabit peanut monkey
If you have a Glasurit jobber they probably sell RM as well. It's a pretty rare car. Stick with the 22 line is my vote.
1981 911SC Targa |
I would talk with 962 Porsche in paint forum. You can always use rm line for your primers and sealers then shoot 22 that will save you some cash. The limco 2k primer called 800k is a good 2k primer and it's only $90 a gallon compared to the rm and glasurit.
Most painters will talk you out of 22 line especially for a driver and tell you to go with 55 line. Go talk with your basf jobber best bet. |
Targa_PB_78_SC
Hum chalk, do you mean this color? Definitely like it!
That looks like it has flake. Its the solid light grey.
Lyndon |
![]() Chalk no flake. Tim |
Under the radar
Dupont also makes a great product. I painted my car with Centari in '85 and it still looks great.
Intersting. painted over the stone chips on the bonnet. ( rust ) . They were bubbles in the paint. When rubbed back no rust until you got to the bare metal. Metal. Primer . Original paint and the one done about 20 years ago. I'm going Glasurit. Got the car cheap so and extra 500 is not an issue.
Lyndon
![]() 41C outside. Air cond in my man cave at 24C. Does it get any better.😕 |
Very nice garage. Have fun and looking forward to seeing the finished product. It's all about the prep-work. Cheers.
'71 914-6 #0372 '17 Macan GTS |
Highly recommend limco 800k under your 22 line for cost savings $99 a gallon. 29f here your a lucky man.
Where do you live that it's 41C in January ?
1986 Bosch Icon Wipers coupe. |
I'm blocking the car and priming. What are your thoughts on underside of the bonnet and engine lid etc.
I can't really get the same blocking effect and I'm thinking no primer just paint after a good scuff. I don't want to end up with a thick coat on these areas. ??? Lyndon |
41C makes me think you live in Australia. That means you can buy Prepsol. i'd scuff the surface then get it really clean with Prepsol and go for it.
Great work area!!! |
![]() For interest. If you can read my scribble. The various current greys. Lyndon |
