My turn to be stupid...
So last week I replaced my tail lights and everything looked great...except...no reverse lights. My Oregon inspection is due next month and while I'm not sure whether they do all the safety checks they used to I figured I need to have working reverse lights anyway. So, I found a couple of threads here on reverse light issues, crawled under the car and saw that yes, only one of the two wires is actually connected to the reverse light switch.
Stupidly, I didn't think about that switch going straight into the transmission fluid reservoir (thought the washer and tight fit should've told me something). I narrowly avoided a face full of transmission fluid but I managed to get the switch back in place pretty quickly.
Before I start taking other stuff out, I just want to make sure that I have the right plug for the filler plug. It is on the driver side, correct? The one am I pointing to in the pic below, right?
Old 06-01-2019, 11:26 AM
carreradpt's Avatar
Yep, that is the one.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 06-01-2019, 12:12 PM
Correct. Use 24Nm / 17,7 foot pounds when tightening both the drain and the filler plug
Old 06-01-2019, 01:09 PM
Thanks guys!
Old 06-01-2019, 04:17 PM
HarryD's Avatar
They do not have a safety check in Oregon, only emission testing. That said, you should do you own safety check regularly. Things like:
Lights working
Horn working
No excessive leaks
Wheels bearings tight
Ball joints tight
Shocks ok
Doors work ok
You get the idea.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-01-2019, 04:59 PM
