Brake pads for manual brakes
My car has a hard brake pedal that I attribute to old cheap compound. I rebuilt the calipers with caliper kits from our host but I did not replace the pads.
Looking for recommendations for pads with good street performance over noise and brake dust.
Your $.02 please. Thanks
1973.5 911T ——-1974 914/1.8
Old 05-30-2019, 07:10 AM
(man/dude)
Jonny042's Avatar
A lot of the "better" compounds are going to make the problem worse as performance pads will tend to be a bit "hard" until heated up a bit.
Might be worth a phone call or email to Hawk Performance to see which of their compounds has the best cold coefficient of friction.
I'm guessing their HPS or HP+ compound, or they be able to point you in the right direction.
EDIT/PS - As part of the backdate on my project car I eliminated the power brake booster so will be interested to know what you come up with. I intended to contact hawk and maybe one or two other manufacturers to get the same info.
From what I can tell street pads will normally have a cold cf in the .3 to .4 range, but some race pads will have a cold cf as high as .5 and even greater when hot.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 05-30-2019, 08:33 AM
Called Hawk and Porterfield, decided to go with the Porterfield R4S compound. I'll report back when I've tried them out.
Old 05-30-2019, 09:46 AM
(man/dude)
Jonny042's Avatar
Were they able to give you some data on the cf of the R4S compound? I have them on my 87 coupe and they seem good but never given them much thought.
Old 06-04-2019, 05:49 AM
(man/dude)
Jonny042's Avatar
A quick google search answered my question - R4-S will give a cf up to .41 according to porterfield. This is interesting:
Old 06-04-2019, 05:59 AM
EBC has a good reputation as well if you are looking for another company to compare against.
Old 06-04-2019, 06:34 AM
