How To Measure Fuel Pressure 1983 SC 3.0 With Webers
Hi,
I have a 1983 3.0SC with weber carbs.
I want to check the fuel pressure but sure quite how to do this.
Can someone point me in the right direction.
Thanks.
Old 06-02-2019, 01:50 PM
The best thing to do , is to go to the PMO website and purchase the fuel pressure regulator that they sell. It is a regulated return and that is vital . Fuel pressure for webers wants to be less than 2.5 psi
This is sound advise ,have fun
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 06-02-2019, 02:16 PM
Can check the static pressure by temporarily connecting a fuel pressure gauge to the end of the source line. If using the factory CIS fuel pump, as icarp suggested, it must be pressure-regulated with the factory FP return line to the tank. The suggested FP to the carbs includes all line restrictions including filters, hose connections/adapters and/or shut-off valves.
Old 06-02-2019, 02:57 PM
HI - I have a fuel pressure regulator already attached but just wanted to check it was delivering as expected as it was fitted by PO.
Old 06-03-2019, 02:47 AM
proporsche's Avatar
you might want to get from our host this tool;-) check the fuel level in your carbs
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-03-2019, 03:03 AM
Under the radar
Trackrash's Avatar
A number of guys keep a pressure gauge installed all the time. The stock pump and lines with the correct regulator will work fine.
I am running an aftermarket, Facet, pump. I recently checked my pressure.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-03-2019, 10:34 AM
