78 alternator replacement w Valeo wiring?
Hello, I am Replacing a 78 alternator with a Valeo alternator. I have Read about the internal and external voltage regulator differences. I am Still confused if I go with Valeo internal regulator, what do I do With the black wire that is for external regulator? Also, what problems may I have With my gauges if I select the newer internal regulator. Thank you.
Just fold the black wire back and remove the old regulator. No need for the black wire. No difference in the gauges
Thank you for response. Does the alternator light in the gauges now become inactive with dead heading the black wire?
The light is in the blue wire circuit.
76 911S Targa
Alternator shaft is a different diameter. The Valeo fan/alternator/pulley nut is 24 mm instead of the 22 you had.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Yeah, the cup washer hole probably needs to be enlarged to fit the new shaft. Die grinder or rat-tail.
Carl v S
The SEV Marchal alternator on my 78SC ROW failed about two weeks ago. Replaced it with a
Brand: Bosch Part Number: AL9341X Item Condition: Remanufactured Item Description: Alternator Manufacturer Brand Description: Reman Alternator Quantity Needed: 1; Fitment Notes: Optional;70 A; Cost $164.84 including shipping on eBay. Works great, so far. The nut was included now 24 mm wrench size instead of 22mm. Used the existing external regulator. Sent from my iPad using Tapatalk |
76 911S Targa
I enlarged the cup washer described by John Walker using a round file in a motel parking lot. I highly recommend the die grinder alternative in your own shop,
