Rust oleum truck bed coating works great and is affordable. Neutralize the rust and go to town. It comes in a spray can or gallon.
You can get it in any color you want as long as it’s black.
Tony
Old 10-19-2019, 09:47 PM
Just use some Ospho on the rusty areas (probably only surface rust) and buy a quart of the brushed on Por 15. It hardens with no issues, easy to apply you donít need to mask anything off ,and is very durable.
78 911 st backdate
87 944
Old 10-20-2019, 02:31 AM
GaryR's Avatar
Send a message via ICQ to GaryR
I would go to an auto paint store, ask if they have single stage enamel in cans (preferably with a hardener portion), and go from there. Give it a few days and it will be as hard as a rock and ready for your installation, no comparison to Rustolecrap..
Gary R.
Old 10-20-2019, 03:49 AM
Figured I'd update with photos of the finished product! I ended up painting the interior with Rust-Oleum clean metal primer, then the black Rust-Oleum metal paint. It worked well, though if I did it again I would use gray paint instead of black. After the paint I laid dynamat all over the tub (not solid, I did strips and patches), then dynaliner in the back seat area where the heavy sound deadening pad was. It is definitely quieter than it was before I started this project.
Here is a build thread I did with some additional pictures of the interior work I did. Need to go finish that write up soon!
https://r.tapatalk.com/shareLink/topic?url=https%3A%2F%2Fforums%2Epelicanparts%2Eco m%2Fshowthread%2Ephp%3Ft%3D1033928&share_tid=1033928&share_fid=844&share_type=t&link_source=app
Cheers,
Noah
Sent from my Pixel 2 using Tapatalk
Noah
1986 3.2 Carrera
Old 10-20-2019, 05:05 AM
I just painted my interior black.
This is two coats of Southern Polyurethane's black epoxy primer.
I will topcoat it with a satin black with hardener.
www.ahhgaragetime.com
Old 10-21-2019, 10:29 AM
Look good.....very good job. I used Rustoleum 7776 satin black on my interior. I had no rust, even surface rust.
If I had rust, I would take it to bare metal and use acid etching primer on bare metal and then Rustoleum.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 10-21-2019, 04:16 PM
All opinions varies from one individual to another based on their experience and budget - Most of "epoxy" painting companies are very good by most standards - except for lower end companies that sells epoxy paint results poorly.
So I think either POR-15 or Rustoleum paint are very efficient for any metal work projects - POR-15 is expensive thou for a small pint paint can as opposed to Rust'lum is cheaper by a gallon can.
Do whatever you are comfortable with any epoxy paint for metal work according to your budget for they are all durable that lasts for years.
Old 10-22-2019, 11:13 AM
Tags
floorboard , interior , paint , parcel , shelf
