How to remove side view mirror controller??
I am in the process of removing the drivers door panel and not sure how to remove the controller.
I am seeing two small holes that are holding the controller/switch to the door cap. Does this piece need to be unscrewed by using the two holes? |
1st, you need to specify what year of your 911 it is and next is picture of the item you need help with...
Ivan |
On mine (MY1985) I use a circlip plier to unscrew the top using the two holes.
| All times are GMT -8. The time now is 11:58 PM. |
