-   -   Oil Add Trick (http://forums.pelicanparts.com/porsche-911-technical-forum/1031690-oil-add-trick.html)
tdw28210 06-08-2019 12:56 PM
Oil Add Trick
All,
Been using this for a few years now. Just took pictures today. I have a couple super strong magnets on the AC plumbing on the deck lid of my '87. I use them to support a metal radiator funnel when I am adding oil. They won't hold a full bottle, but strong enough to keep the nearly empty bottle dripping.
Hope this helps someone else. And yes, the magnets have been in place for 2+ years now.
http://forums.pelicanparts.com/uploa...1560027261.jpg
dg567 06-08-2019 01:11 PM
Very cool trick!
Blamecanada 06-08-2019 01:16 PM
Great idea.
Thanks for sharing. Love that idea. Going to use it for sure. Cool funnel as well.
HarryD 06-08-2019 02:39 PM
I use a radiator funnel. I can jam it between the filler neck and the lip of the engine room.
piscator 06-08-2019 04:27 PM
That's super cool! Thanks!
kanadary 06-08-2019 04:38 PM
I just pour it straight in from the bottle. The size and angle of the opening makes it relatively easy without spillage. Now if I have to only put in a quarter of a bottle that could be a problem
Arne2 06-08-2019 05:22 PM
I did something like that on my '84. Won't work on my new-to-me '72...
HarryD 06-08-2019 06:35 PM
Tried that. I am not coordinated enough to do this reliably. :rolleyes:
Uwon 06-09-2019 07:55 AM
For those who have other obstacles.....http://forums.pelicanparts.com/uploa...1560095623.jpg
Cheers,
Johan
kent olsen 06-09-2019 08:12 AM
Don't have that problem on my 72!!
smadsen 06-09-2019 09:55 AM
Come on! What's an oil change if you don't get at least a quart on the floor?
James Brown 06-09-2019 12:29 PM
http://forums.pelicanparts.com/uploa...1560112045.jpg
I just let them handle it, what can go wrong?
Uwon 06-09-2019 04:12 PM
They’d still be looking for the engine in the front.....http://forums.pelicanparts.com/support/smileys/wat5.gif
al lkosmal 06-09-2019 08:33 PM
That is a great idea and beats my bungie cord method for sure.
regards,
al
pmax 06-09-2019 08:57 PM
Great idea.
Now if we can get this working with ...
https://rotella.shell.com/en_us/prod...omo-image.jpeg
Rawknees'Turbo 06-09-2019 09:18 PM
Originally Posted by pmax (Post 10486403)
Great idea.
Size matters, pNutz - all you need is a bigger, errrrrr, funnel!!! :)
Bill Douglas 06-09-2019 09:19 PM
Easier still is to cut the bottom off a plastic drink bottle and use that as a new CLEAN funnel each time. The size of the neck is such that it jams in the filler hole and doesn't move around.
pmax 06-09-2019 10:17 PM
http://forums.pelicanparts.com/uploa...1560147462.jpg
tdw28210 06-10-2019 07:37 PM
Had a PM about the funnel. Look for a "transmission funnel."
A horse with no name 06-10-2019 10:41 PM
Ketchup bottle oil funnel
The magnet/funnel looks good...Something that has worked well for me for years has been a 1 litre plastic Heinz Ketchup bottle...I just cut the bottom off of it -The spout fits into the oil fill pipe, and even stands up by itself....'Easy Peasy' :)
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
