rfix'n's Avatar
3.6 conv 2"DME rubber grommet
Okay, I have the whole cut and wires through but after an hour of trying can't get the rubber grommet in there to seal the whole. Do I need a bigger whole or am I missing something. Trick to getting rubber grommets in, I've got it lubed up with silicone.
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 03-21-2003, 10:45 AM
Kevin Stewart's Avatar
did you use a 2 inch hole saw?, Kevin
Old 03-21-2003, 12:40 PM
rfix'n's Avatar
Thats pretty original spelling I have going on up there, whole?.
Yep, used a 51mm whole saw.
Rob Fix
'78 3.6L SC Targa
Old 03-21-2003, 01:28 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Originally posted by rfix'n
Yep, used a 51mm hole saw.
I used a 2 1/2 inch hole punch. That would be 63.5mm. I measured the grommet and came up with 60mm as the ideal size. Everything fit perfect. I fed the harness from the engine bay into the passenger compartment and used pliers to pull the grommet in place.
Is yours that different???
ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-21-2003, 02:01 PM
hallo
Ingo ,like always right on the Spot . 60 mm is the original hole in the 964/993 .
harald
Old 03-21-2003, 02:25 PM
I used a 2 1/2" hole saw and was able to push the grommet securely through the engine pad. To really do a nice job you would have to place the grommet between the sound pad on the exterior and behind the seat pad.
Old 03-21-2003, 02:41 PM
rfix'n's Avatar
Since I already had a 2" hole cut I couldn't use another hole saw, I enlarged it with a die grinder and, it fits. Instructions I have say 2" hole, thats why I started there.
Thanks Guys!
Rob Fix
'78 3.6L SC Targa
Old 03-22-2003, 07:39 AM
rfix'n, my instructions say the same thing, Kevin
Old 03-22-2003, 08:41 AM
