Washer fluid pressure
Just installed stock washer fluid pump, new hose and squirt nozels. All factory porsche parts. Washer fluid squirts all over the garage and very little gets on windscreen. What have I done wrong? Do I need some kind pressure regulation device so I can adjust the spray pressure?
lake wales fla
Try adjusting the nozzle eyelets in the washer nozzles, I use a hypodermic needle end that I put a slight 45 kink in the tip.
With a small needle inserted in the nozzles you can point the nozzles towards your windscreen.
However, it still sprays windscreen + roof on my model 85.
__________________ 1985 Carrera 3.2 |
Thanks guys! That did it. Appreciate the posts
