I had the same issue over the last couple weeks. Car would start fine if i drove it every day, had to put a trickle charger on it if it sat for over 3 days. Its been discharged several times in the last few years.
Checked voltage resting 12.3v charges at 13.7 with car running. New battery is on its way, 3 months out of warranty. I need to fix dome lights windows roll up with door open. |
Late vehicles' alternators (14V+) are designed for use with AGM batteries not early 911s. Avoid using AGMs, if the vehicle isn't designed for its use!
Dave |
I don't drive it much the last 2 years. Always on tender.
1986 Bosch Icon Wipers coupe. |
Update:
Left it off the tender the last time I drove it. Tender could not revive. I hooked up a 12v charger overnight Battery now showed 12.65v at rest 14.05v while running Took it to FLAPS He attached a device that read 850 (Battery is only rated 765 CCA) Device said green/OK. Took it home Put in car Went for a drive Left it off tender I will see if the car starts on Saturday (3 days)
