Very entertaining and informative post. Keep up the good work and keep updating us.
Thanks Tony |
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
That line is for the brake booster if your car has one.
Rutager West 1977 911S Targa Chocolate Brown |
This is great! Love these kind of videos! Sent from my iPhone using Tapatalk |
Ok gents, parts are starting to roll back in, and I'm turning up the boost! This is my LONGEST VIDEO YET, covering a TON of things. In this episode, I cover the following: Refinishing a fan shroud, installing some gold foil lined sound deadening, and then I dive into stopping as many oil leaks as possible: Pulley seal, Nose Bearing Seal (Tom Amon Seal), Intermediate Shaft Seal, Triangle of Death, Timing Covers, Oil Pressure Sender, Temp Sender, and Oil Cooler.
https://www.youtube.com/watch?v=ovhYdKFrkgg Let me know what you think, editing this one was a beast.
Those pulley seals hardly ever leak, unless they are damaged. It is the O ring around the nose bearing that will leak. We just did the aluminum ring on our 2.7 short stroke, which has your 2.9 engines 93mm bore, but on a 66mm crank. So far it appears that the seal ring kit has corrected the oil leak around the nose bearing area. That red RTV makes a mess. We disassembled a 2.7 that was leaking oil profusely, like yours, from the top of the case, and running down. The problem what’s, when we got down to splitting the case, it literally fell apart, once the bolts were removed. They had used red RTV as a case sealant. I hope they didn’t use it to seal your case, otherwise your just wasting your time, and will have to split the case to stop all of the leaks. A 2.9 mag case engine is a high stress engine. You’ll have to make sure that it does not run too hot, or it will twist. We fabricated our own 93mm cylinders by boring out 90mm nikasil cylinder cores, and pressing in 93mm steel sleeves. We have what are similar to 93mm biral cylinders. I believe JB racing also fabricates this type of cylinder. We are running Cosworth pistons and modified Weber 40IDA carbs. It literally screams at 7300 RPM. Good luck with yours.
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke 1973 1/2 911T S optioned sunroof coupe (in progress) 1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels 1999 996 Carrera Cabriolet Last edited by rgofast; 08-01-2020 at 08:20 AM.. |
Thanks Ja |
The case looks to be sealed with some sort of blackish compound, not RTV. I think the engine was leaking oil, and the PO took it to an 'import shop' that was definitely not a porsche shop, and the mechanic was a total hack. It looks like they basically just took stuff off, slathered RTV on it, and put it back on. Oil return tubes, rocker shafts, thermostat, valve covers, etc. I don't believe that hack touched the case or the heads/jugs/etc.
Okay, so I have a question... is there a BUDGET way to do the clutch? I looked at pelican's pricing... and man another $1000 is hard to swallow right now. Can I get away with just taking the clutch apart, replacing the throwout bearing, getting the flywheel machined, and maybe just checking on the friction material... and just replace that if necessary?
Also I did not lube the shaft when installing the pulley seal. Is that bad? Will it burn up? Should I just order another seal and pull that one out, lubricate the shaft, then install a new one? Let me know guys!
Ken 1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS |
Thanks man. Will pull them off tomorrow and see how they look.
For your clutch: I took a very similar approach. I made sure the flywheel was in good shape as well as the pressure plate, and then I scooped a friction disk from someone who was selling in the FS area on the forum that was not ever used (“SACHS” brand) for whatever reason. I was able to save a couple bux on that in the end.
'Inherited' car: 1979 911SC - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 16 Subi Outback with some light visual custom stuff. |
Why am I reading that you should preemptively replace the release fork?
Is there a way to measure the friction material on my disc, to determine if it needs to be changed or not? It engaged fine, the only issue I really had was shifting into 2nd.
From what I understand regarding the release fork is that it is prone to breaking without warning.
...for the record, I did not replace the release fork when my car was in pieces.
Alright guys, still no answer on the pulley seal... do I need to redo it with lube on the inside edge?
Anyway, new episode is up! Teardown of my clutch, inspecting everything, and changing out the flywheel seal. Also geeking out about my plated hardware and rebuilt alternator. https://www.youtube.com/watch?v=90Mxo1lbFqA
Ok I’m stumped. How do I get this rocker shaft out to install RSR seals
![]() I can't push it towards the rear of the engine because of the timing cover. I can't push it forwards because of the timing cover. What do?
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com Last edited by ADDvanced; 08-06-2020 at 07:14 AM.. |
Somebody has to have a trick for this.
Assuming the fastener is backed off, source a reverse (expanding) pliers with some sockets for spacers. Push the rocker shaft out toward the middle. If you need further encouragement, use a long drift punch to evenly drive it out.
Can also heat up the area around the rocker shaft to expand it, then shoot some Kroil around the shaft and shaft hole. ![]() Is the camshaft housing coming off? if so, take it off. The rocker shaft could be binding when torqued in place. Sherwood |
Tried a long punch but unless it was curved there was no way to get it. I posted a few other places for advice and wound up using a socket and a screwdriver as a prybar. Worked aces! Have these three out, will be cleaning them up, installing RSR seals, and reinstalling today. Prelube w engine oil? Will read the book to discover more.
Another snag; I was skimming the engine book and in the disassembly, it didn't seem to mention marking the pressure plate or flywheel assembly prior to removing them, so I didn't. I am now reading they are balanced with the crank as an assembly. What should I do now? My machine shop charges $150ish to rebalance, but they don't have a crank to bolt it to.
I do not recall the flywheel and the pressure plate having a balancing situation - on mine.
I DO however remember the flywheel being directional. Meaning - on my engine - the 6 bolts (I believe that it was 6) that were there had a pattern so that the flywheel will only install one way. (IE: the holes on the flywheel are not perfectly spaced, and forces the mating to be one-way only). I think that is the “balancing” that is being referred to, unless someone can help further.
Thread Tools | |
Rate This Thread | |
