Help identify transmission?
I see 915/XX 734 8186
XX=ground off
7= 6cyl
3= ROW 5spd
4= 1974
8186= SN
So a 915/06 correct? Being a ROW trans is surprising, is that really what the "3" means?
1978 SC Targa
Old 06-20-2019, 08:48 AM
Peter Zimmermann's Avatar
From what I can tell you are correct that your trans is a 915/06, but I find no info that would indicate that the "3" is a RoW unit. The "3" in this case simply means the trans is a 5-speed, with 7:31 ring & pinion, that was fitted to '74 911s, 911Ss, and Carreras. I find no mention of RoW models in my 1974 Tech Spec book.
If I remember correctly, in Tobias Aichele's book "PORSCHE 911, FOREVER YOUNG," the words "Rest of World" (RoW) appeared to describe a model for the first time in 1978.
Keep the Shiny Side UP!
Pete Z.
Old 06-20-2019, 01:00 PM
Thank you Pete, appreciate the info.
I've been using info from this site -
Blue Sky
at the bottom of the page under "Serial Numbers" they mention
3 = 5 speed Europe and RoW
Unfortunately not the transmission I was expecting (included in the purchase of my '78). 108mm 4 bolt two pin CV flanges, 7:31 R&P and mech speedo make it less than ideal for my SC...
1978 SC Targa
Old 06-20-2019, 01:46 PM
Usually, when RoW is mentioned, it means countries "other than" the U.S.A., Canada and Japan. I think that Blue Sky didn't get that memo!
Sorry about your trans fiasco (I hope that your '78 car has a transmission in it!), maybe someone with a '74 car will come along and buy the early trans from you.
Pete Z.
Old 06-20-2019, 03:22 PM
gearhead
In 1974, there were 3 gearboxes, a 4spd, a 5spd, and a Sporto. Every spec, Carrera, S and normal, got the same thing.
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 06-21-2019, 10:59 AM
