-   -   Engine case to oil line fitting what size and who sells them (http://forums.pelicanparts.com/porsche-911-technical-forum/103277-engine-case-oil-line-fitting-what-size-who-sells-them.html)
bfrenz 03-22-2003 06:00 PM
I need the fitting that goes into the engine case and connects to the hard oil line that returns to the oil tank. Anyone know where to find one. I can't even find a picture of it on parts diagrams. Or does someone know the specs on it. Its a double male fitting.
Doug Zielke 03-22-2003 06:42 PM
Part # is: 999 136 008 00 (Union)
and you will also need:
900 123 011 30 (Sealing ring)
You're welcome.
Jandrews 03-22-2003 06:51 PM
While we're on this topic...
Does that sealing ring that Doug mentions below fit the union with closely? The one I got was loose around the union and I am worried about leaks. Haven't started it yet, but I am willing to bet I'll be pulling that Heat Exchanger and re-doing it.
Also, does anyone use liquid teflon or any other type of pipe sealing compound on these oil line junctions?
Thanks,
JA
bfrenz 03-22-2003 06:54 PM
Thanks Doug
