85 911 Warm start Issues
So Iíve been doing a ton of research on past warm start threads but havenít had the exact same issues as most of them and some that are really close donít have posts whether they fixed it or not.
So my car Is an 85 911. When I drive it then shut it off if I restart it within 20 minutes it starts fine. If I try and start it after 20 minutes it will crank for a longer period before starting. I usually cycle the key to off once or twice and then it will start like normal. If I donít cycle the key it will start but takes a long time to start and usually starts at low rpm and climbs to normal idle.
I initially thought my check valve was bad and replaced it but it continues to be the same. On the first start of the day it starts normal every time. Sometimes if I leave it outside all day and try to turn it on it will do the warm start issue but this usually doesnít always happen. My fuel pressure is reading about 32 psi running and residual after 20 minutes is the same. I Need to check the resistance not the cht also. Do you guys have any other suggestions on what I should check.
Thank you
Old 06-22-2019, 05:09 PM
oops
Old 06-24-2019, 02:37 PM
Any news on this one? I may be having the same issue...
For those interested in my momo collection, feel free to have a look at my instagram profile _more_momo
Old 07-14-2019, 10:50 AM
