8 Pin CDI Rebuild
I am almost finished with my 76 930 motor and need to sort out ignition. I have looked at the usual suspects that rebuild CDI boxes but many don't support the 8-pin CDI boxes. Does anyone have a recommendation for a trusted vendor to go through my 8-pin CDI? Thanks!
Old 06-27-2019, 03:50 PM
MBAtarga's Avatar
Did you contact Pelican user ischmitz?
Mark
'83 SC Targa - since 5/5/2001
Old 06-27-2019, 04:41 PM
Years ago,
I needed my 76 turbo 8 pin rebuilt and sent it to Zims in Texas
Try Bob Ashlock, on PP.
Bruce
Old 06-27-2019, 05:41 PM
gumba's Avatar
Bob Ashlock rebuilt my 8 pin cdi a few years back.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 06-27-2019, 06:14 PM
Jonny H's Avatar
We can put our modern electronics in your 8 pin case or we have a complete 8 pin replica box.
www.classicretrofit.com
Old 06-27-2019, 10:16 PM
I used a 6 pin on my 77 930. Eliminate the two wires that go to that condenser looking module attached to the panel, get a 6 pin plug and swap the wires from the 8 pin plug in the correct order.
206 637 4071
Old 06-28-2019, 03:59 AM
Been here a while
+1 for Bob Ashlock. Good guy, great work, fair prices, quick turn-around. What more could you ask for?
Found a period correct hotrod motor, but still looking for 1972 911t motor, 6121622
Cayman R Sportomatic and some other cars
Old 06-28-2019, 04:45 AM
Another vote for Bob Ashlock.
Old 06-28-2019, 05:47 AM
digitaldgp's Avatar
Another Vote for Bob Ashlock, he just finished my CDI.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 06-28-2019, 07:04 AM
Those Bosch CDI units are very reliable and rarely if ever fail. Many assume that this CDI has failed because it doesn't buzz
like the 3/6 pin Bosch units. Do a Google search for its part numbers; 0 227 300 002, 0 227 300 003, various rebuilders.
Typically the problems are; a bad 12V power input or a bad distributor signal, both easily checked with a volt/ohm meter.
Avoid using the Bosch silver coils with any CDI units
Dave
Old 06-28-2019, 07:29 AM
Interesting read here; 6-pin SC/Turbo CDI unit repair documentation
Dave
Old 06-29-2019, 06:52 AM
Jonny H's Avatar
A 6 pin box wonít drive an early Turbo tacho. Youíll need one of Bobís adapters too.
Old 06-29-2019, 07:00 AM
It looks like Bob is the go to guy. Thanks for the recommendations!
Old 06-30-2019, 12:23 PM
Seems to drive mine.
206 637 4071
Old 06-30-2019, 01:20 PM
Jonny H's Avatar
Check the year of the tacho, probably a later one.
8 pin boxes produce a 400V positive spike to drive the tacho. The tacho on the early Turbo is therefore more like a 69/70 tacho (that was driven direct from the coil). 6 pin boxes are just 12v so will only drive the low voltage ones (as fitted to the later Turbo).
8 pin boxes will drive tachos designed for 12v but I canít imagine it is very good for the tacho!
Old 06-30-2019, 01:57 PM
Thanks, I'll check the date stamp.
206 637 4071
Old 06-30-2019, 04:26 PM
porschetub's Avatar
Bob is a great guy to deal with,happy to help me with my ignition setup also.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 06-30-2019, 10:28 PM
I received my box back last month from Bob an dit is an absolute work of art!
Old 08-27-2019, 03:28 PM
the Bosch CDI is a 50 year old design with 50 year old components.
A modern CDI is much much better. Even having a soft rev limiter is great plus more spark.
Best day of my life is when I dumped that old Bosch!! My 911 came alive with a good modern unit.
I know you won't agree. Loren
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 08-27-2019, 09:29 PM
