Steering Wheel Wouldn't Turn While Driving on Highway
Hi All,
I was cruising on the highway at 65 today, when I felt the steering wheel bind up a bit on the right side. I have never experienced this before and thought it might just be the road. I kept driving while checking the wheel. Soon enough I realized that the wheel had bound in either direction except maybe +/- 5 degrees. I turned on my hazards and was able to navigate off the highway onto a side road.
I pulled the car over and shut down. With some force I was able to turn the wheel. I limped into a gas station and the wheel seemed to free up. However, when I was testing it, it kept binding randomly. It didn't feel safe to continue so I towed 50 miles home.
Any clue what this might be? There is no play in the steering wheel so I think the upper steering shaft bearing is ok. The U joints looked ok and greased. Maybe it's the lower shaft bearing?
I'm going to diagnose tomorrow, but I'm not sure what to look for. Any help is appreciated.
95 993 C2
Old 06-29-2019, 05:24 PM
Senior Member
Superman's Avatar
Two things strike me as essential. Being able to brake, and to steer. Important, these are.
Mocha 1978 911SC. "Coco"
Old 06-29-2019, 06:10 PM
Mo money = mo parts
Did it feel like the steering was unresponsive or "binding", or was the column locked in place? There are a few threads that I found with a quick search depending on your symptoms.
Either way, it would definitely un-nerve me.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 06-29-2019, 06:19 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Probably your steering column bearing has disintegrated and a couple of ball bearing are loose. You are very lucky it didnt "fully" lock! There are a few options out there now that are better than the OEM version.
Marc
Old 06-29-2019, 06:22 PM
MBAtarga's Avatar
I just did a site search on "steering column binding" and it returned many threads - these caught my attention and list several areas of possibly being the culprit:
Steering locked for a moment, ideas?
My steering jams - YIKES!!
Mark
'83 SC Targa - since 5/5/2001
Old 06-29-2019, 07:22 PM
The steering felt responsive, but there was resistance when I tried turning the wheel. In other words, the steering would have worked if I could turn the wheel. It didn't feel like the steering lock mechanism (nor could I even get the wheel turned to that point).
95 993 C2
Old 06-30-2019, 08:04 AM
I don't think it is the upper steering shaft bearing as there isn't play in the steering wheel. From what I've heard, when the upper steering shaft bearing goes, the steering wheel has significant play in it (0.5"-1"). Please correct me if I'm wrong.
This is what leads me to believe it is the lower steering shaft bearing.
95 993 C2
Old 06-30-2019, 08:07 AM
Thank you!! I tried searching as well and only found 2 threads that loosely described what I was feeling. Let me read through these before I diagnose today.
95 993 C2
Old 06-30-2019, 08:08 AM
proporsche's Avatar
i am just now doing a job on one 911 with the same problem .It most likely your steering shaft bearing.Inside the rubber is needle bearing if it is old the little pieces will fell out creating the problem...one more thing..to investigate you have to remove the allen head bolts,but be careful they will strip easily..so hit it with a hammer before trying to loosen it...with the allen socket on the bolt...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-30-2019, 09:41 AM
proporsche's Avatar
here is how it looks when it is kaput....
Old 07-01-2019, 01:28 AM
IROC's Avatar
I had this happen a couple of times about 25 years ago. Scary. My assumption at the time was that pieces of the failed plastic steering bushing (I had already replaced it) had fallen down into the steering column and were getting caught in the steering lock mechanism.
Right or wrong, I removed the ignition switch (along with the steering lock mechanism/bar) and cut off the end of the locking bar with a hacksaw. Crude, I know, but this completely solved the problem. It never happened again (even 25 years later).
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 07-01-2019, 03:50 AM
I might do this just to be safe. How difficult is it to remove the ignition switch?
95 993 C2
Old 07-01-2019, 04:44 AM
I took everything apart yesterday. If you want more detail, check out my Instagram account (@valveandpiston) where I documented the process.
It looks like the culprit was the lower shaft bearing. When I took the bushing/bearing off, it felt like clay was lodged in the needle bearings - very gunked up. After cleaning the bearing with brake parts cleaner and applying some silicone lubricant, I felt that it could be salvaged. I also cleaned the U-joint, but did not apply any lubricant. The U-joint was very tight. I took it for a test drive and didn't feel any symptoms. See below for before/after:
Before
After
And a picture of the steering shaft, which I cleaned up as well.
However, I am still a little worried that this was not the entire issue and it could be the steering lock mechanism...
95 993 C2
Old 07-01-2019, 04:58 AM
IROC's Avatar
This was a long time ago, but as I remember, it wasn't difficult.
Mike
1976 Euro 911
Old 07-01-2019, 06:50 AM
