For those with upgraded AC systems, what should typical vent temps be?
My car is in for basic maintenance service and I'm having them service the AC while it's there. I've replaced the entire factory AC system with the Classic Auto Air kit.
What temperature should I expect to see from the center vents on high? |
I know that is where most people measure the temps. I can't get a thermometer to just hang there as I drive. Normal driving conditions is the real test. I had an 1985 Carrera, and the little bitty vent on the sides of the dash. I can slide a standard AC temp gauge in that as go for a drive. It will blow 38 to 40 degree air from that vent at full high speed blow on a 100 degree day. Even after stopping for lunch and the car sits in the sun for an hour. Get in, go and 15 minutes later that side vent is blowing cold. The center vents blow so much air with the upgraded fan kit I bought from Griffith's I have to divert it away from my face if I have it max cold and getting 38 to 40 degree air.
My ultimate winning moment was in Savannah, GA in August, full sunny day and stupid heat index. My wife asked me to turn the temperature up because she was cold on a lunch time trip. :D I have the four condenser Griffith's system, and the variable speed fan switch and his hurricane blower. His stuff is expensive, but top quality. |
i have his evap and front and rear cond,.
40's maybe 50. that's driving with fan on hi, BUT I have to turn the temp up because the evap will freeze over. people will say they get down in the 30;s or even 20's but a proper system should never get that cold BCAUSE of the evap freezing over and the low side pressures can get too low. the 911 does not monitor the low side like most cars do, they just use an evap temp probe to "control the low side" not the best way to do it. part of the reason you can get down to 30 is if you set the fan speed to low and/or the air flow over the evap is low, in part due to the low CFM out of the stock fan. you also need airflow over the condensers to get proper or accurate temps. |
It would be helpful to see what temps folks see with a properly functioning factory system in comparison.
a lot of folks measure with an IR/laser infrared thermometer. It simply won't be accurate. These things are designed to measure the temperature on a surface, not air temperature. Mine showed temps well below freezing, 20 degrees F at times. It was suffering from a thermal shock condition. Instead, I used an instant read analog kitchen thermometer in the center dash vent.
I've got the full Kuehl/Griffith's kit too, 4 condensers, the high efficiency evaporator, the upgraded fan/blower. Running R-134a, which won’t cool as well as R-12.....you’d be hard pressed to get R-134a to give dash temps below 40 degrees, in even a modern car. From my in-dash thermometer I get temps right around 40 degrees, occasionally a 39, most often a 41-42, fan on high, car in motion, system running for a few minutes or a few hours. Lots of compromises here, and I’m sure lots of variables in terms of how temps are being measured, ambient temp, relative humidity, choice of refrigerant, methods of measuring temps. |
For a point of reference, my stock (r134a conversion, ND compressor, factory condensers & evap) runs 48-50 degrees at the center vent w/fan on high and car in motion. That's with a fresh charge and ambient temps here in the LV valley at low triple-digits right now.
Try contacting Charlie at https://griffiths.com/porsche/air-conditioning/ one of the best sources for 911 AC info.
It's always good for a laugh to see posts from peeps who apparently can not build a genuinely cold a/c system so then declare that it is either not possible, performance testing is flawed, or it is actually a negative to have super low vent temps. I heart Pelican a/c threads! :D
I have the full Griffith upgrade and can get sub 40 temps on a hot day with the middle fan speed. Using his improved performance evaporator fan the temps do increase slightly with the higher fan speed.
http://forums.pelicanparts.com/uploa...1561753414.jpg |
I thought of you when I posted that (#forum bromance), as there are several members (not like THAT! :eek:) over the years that have posted super low vent temp systems that actually work - no way are we all liars, dumbasses who can't measure temps, or operating systems that freeze up regularly and then don't work worth a dayumn. |
If your evaporator is freezing up, your temp probe is not properly located. I just this spring put in Griffiths bigger blower. When I put the probe back in I made sure it was properly located, and I used a small dab of thermal paste. I have his variable speed fan switch as well, and that comes with s LED that indicates if the compressor is running. I can see the temps get down to high 30s and the compressor kicks off. No more freeze up. Before I could get freeze up, but I just dialed the temp back and kept it from freezing. I figure either way if the evap is just above freezing, it is max cold.
I don’t sustain meat locker temperatures as long as Rawknees, his system is better designed. http://forums.pelicanparts.com/uploa...1561757948.jpg |
I have replaced all my a/c components except the rear condenser and added a Griffins rear fender condenser. I use r12 Freon and it blows 29 degrees on a 90 degree day. Do your self a favor and find some r12
If you are running R134A and it is 100F ambient, then any AC pressure chart will show a typical low side pressure of between 50 and 50 PSI. If you cross reference that pressure with the boiling point of R134A you will find that the boiling point is in the range 45 to 51F. That’s inside the evaporator. You will lose some of that in exchange with the air and on the way to the vent.
Some people are either defying physics or not running R134A or perhaps.... |
What's a reasonable vent temp for modern car? I'm redoing my 86 Carrera AC and was curious what vent temps should I shoot for? So I drove my 2018 Buick Regal Tourx around Austin today with a thermometer stuck in the vent. Outside temp was in the mid 80's and vent temp was between 43 and 45 consistently. It's got that shut-off at a light feature and temps would hit 60 until I was under way.
^ mid 80s would be a pressure of ~40 PSI corresponding to a boiling point of ~45F. So pretty much exactly your readings.
Normal cars seem to adhere to the rules of the Universe. :) |
Yes, we all wuv AC threads...
I’ll throw this one in to the pile: Forget r-134 and r12 Try industrial grade Enviro-safe. Colder than r12! Significantly less pressure on the compressor! Ok, I’m eating popcorn and I’ve bookmarked this thread [emoji3468] |
I have the Classic Auto Air full upgrade kit. I was seeing low 30* temps. But then the system started having issues and tuning off due to excessive high side pressure.
I need to get a new expansion valve from them. I tried Napa and we could not get the right one. Smugglers door would not close. I lowered the pressures to where it would work and still get low 40* temps with insufficient freon on the system. I think insulation in the smugglers box and sealing the blower panel in the evap case helps a lot. Especially on a 100* day. Sent from my iPhone using Tapatalk |
the Porsche does a piss poor job of regulating the low side. yes you can get very very cold air out of the 911 because of this, BUT you risk the evap freezing up just as mine did. when the low side drops to 20 or less you are looking at temps in the 15 to 20 degree range which i have seen on the 911, including mine with an all new system. that's why most cars have a low pressure switch located on the low side that cuts out at around 20 to 24 psi. its to keep the evap from freezing. maybe where some of these guys live that can run in the 20's don't have the humidity that we have on the east coast. yes i go out to the mid west and laugh when people complain of the humidity and its so dry "I" don't even sweat. yes i have to change my clothes several times a day if i am working outside at home. i have been to a month long HVAC school. if your system is blowing below 35 something is not right. for those that want to use the "magical" refrigerant that is colder than anything else do some research and find out what is in it. it usually has propane and/or other refrigerant, like r22. its all about pressure= temp. if you want to try to tell me otherwise then you need to do some reading on it. and yes my probe works, i have to turn the temp up to keep it from freezing. i do have the original fan. low airflow will also make the low side lower and the temps lower. IR thermometer i was in the 20's, i don't like them for that check. calibrate mech thermometers in a glass of melting ice. |
| All times are GMT -8. The time now is 07:17 AM. |
