Long pedal after new calipers- multiple bleeds
Replaced all 4 calipers (nice "new" calipers from Eric) and pads on my '72 T targa. Even after multiple bleeds with Motive and another with a friend the old fashioned way, still have a really long pedal with horrible feel. Not getting any air out but pedal won't firm up. Pedal feel was great before I started...
I've been doing this for 40+ years but what am I missing????
1971 914- original owner 1973 914 2.0 2018 911 carrera T 2016 981 Spyder PTS |
Functionista
Take the pads out and put a thin shim on each side. Press pedal a few times. Remove shims and move pistons back just enough to put (actually force) pads back in. Bleed as usual and again a day later. Search “exercising caliper pistons” for more info..
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Unlikely...
But this is what I did :blush: I put the calipers on upside down. They fitted up fine and worked OK, just a bit spongy. Being upside down the air wasn't floating upwards and out the bleeders. Good luck with finding the solution. |
Vulnerari Praesidio
Firmly tap (HIT) the caliper several times with a wrench while you are bleeding. Helps to move the air bubbles out of the caliper.
"Wisdom is knowing what to do next; virtue is doing it." - David Starr Jordan Last edited by Roswell; 07-08-2019 at 04:45 AM.. |
Diss Member
It isn't unusual for it to take a while for the seal retraction to take a while to settle down but Eric's would be the least problematic calipers available.
The question is if the problem is a caliper or farther upstream in the system. I'd put the car up on stands and use a caliper (machinists caliper) to measure the travel of the pads on each wheel. If one is noticeable longer you have something to chase down. If they are all the same you can look at lines and the master cylinder. Test, test, test!
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
When you removed the calipers, did you remove them one at a time, or did you replace them all at once? If all of the fluid ran out, you might have to bench bleed the master cylinder.
Vintage Owner
I found that taking the car out for a drive on some bumpy roads while the pedal was still less than optimum helped to shake the air bubbles up to the bleeders. One more bleeding operation (I seem to remember I used a pressure bleeder that time), and the pedal became wonderfully firm.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
True story: My neighbors rebuilt his calipers on a 914-6 and went through a gallon of brake fluid without getting firm pedal. I came over to assist and noticed his bleeder valves pointed down instead of up. We swapped sides, and it firmed right up. He was not amused with himself. Funny thing is the very next weekend, Car Talk had a puzzle that is exactly like that. I called the neighbor up and told him to call in to Car Talk to solve the puzzle.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
go out and bed the brakes,,, long travel will go away quickly.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Just talked with Eric and it's probably the new seals retracting the pistons. He mentions this in his FAQ section of his website... Need to bed the pads and seals and get everything hot- not a problem here in Scottsdale this time of year!
Will drive the car though I hate a long pedal!!
Diss Member
![]() When I got home I called Eric to get good rebuilt calipers... __________________________________________________ _____ BTW - To anyone who doesn't know: The "Eric" we are all referring to is Eric at PMB.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. Last edited by Quicksilver; 07-08-2019 at 12:00 PM.. |
Ditto on what Jeff said. It's also what Eric told me to do on mine when I asked him at Rennsport last year. Try it. It worked for me.
1983 SC Coupe Chiffon White 3.0 rebuilt by me 9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch. |
Do this process and you will at least addressed the most common problem after a rebuild. |
