Freeing brake line connections
Putting on new calipers from PMB and in process figured I should replace the flexible lines as I don't know if the ones on the car are original.
In trying to unscrew the connections on either end of the flex lines they don't budge and I'm afraid I'll strip them. Tried heat, penetrating oil etc. Using flared end wrenchs and still feels like they'll strip before they release...
Any ideas?
1971 914- original owner
1973 914 2.0
1972 911 T targa
2014 991 turbo S
2016 981 Spyder PTS
Old 07-04-2019, 09:08 AM
digitaldgp's Avatar
I had the same issue when I installed my calipers from PMB, I replaced the flex lines and the steel tube lines on my 70 911. Problem solved and not running 50 year old lines. Peace of mind. For what its worth.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 07-04-2019, 09:13 AM
BoxsterGT's Avatar
Porsche Crest
Yes, Flare wrenches are a MUST, but even those are sometimes not enough and the old faithful "Vice-Grips" are the last resort.
Of course, you must then replace w new, but when you do, no need to over tighten.
The Flare design works well when just "snug" plus a little.
It's the same w Fuel & Oil Lines. The flare design allows for just "snug" plus a little.
Len
Old 07-04-2019, 11:28 AM
When I replaced my flex lines, I cut the rubber hose so a socket would fit over that fitting, then used a small battery power impact wrench with a tube wrench on the hard line fittings. Save the cut rubber end and plug with some metal bar stock, comes in handy if you want to take the calipers off again like when you do suspension work to seal the brake system.
77 911s
16 981gts
Old 07-04-2019, 02:07 PM
These work really well … they're 7/16" thick … no flex when having to apply more force than a regular flare nut wrench can handle.
1979 SC Coupe (Sunroof Delete)
Old 07-04-2019, 02:31 PM
Yep, same here. A low power impact wrench set at a low setting works great. Run it for 20-30 seconds, vibrates it right off....
Old 07-04-2019, 03:45 PM
