Ballpark cost on mid-year interior if seats already done?
Hi guys - any recent experience/ballpark for a full installed re-trim minus seats for a mid-year 911? Car is already had the interior stripped, dashboard work not required. Basically carpets and headliner and panels...
I know there are a couple well regarded shops down in North San Diego.
I am in SoCal as well.
Thanks!
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 09-14-2019, 08:06 AM
Harpo's Avatar
I just got a quote back from my guy. I was a little disappointed with the quote (higher than I was expecting). I supplied 90% of the leather and he wants just over $1500 for the RS door cards, door tops, quarter panels, quarter panel tops & rear shelf. Maybe the problem is the little bit of custom quilting?
Old 09-14-2019, 09:17 AM
Registered Minimalist
75 911s's Avatar
Headliner alone is a 1500 job imho. Carpet takes finese, I'd say 2500-3k for the carpet, headliner and door panels, more customized stuff would be more.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-14-2019, 09:29 AM
Yikes. Looks like I will need to buy and install as much as possible.
Edit - Forgive my manners, I neglected to say thank you. I thought it, but didn’t write it. I do appreciate the responses!
911 w/ 3.2
Old 09-14-2019, 11:33 AM
82 911 SC - Ancora Imparo
I agree that headliners *should* be expensive, but I have multiple local guys in FL who do quality work and will do it for under $500 if you pull and replace the glass yourself (or have someone else do it). The carpet materials start around $500 for lower quality and go up until the top end squareweave which is more like $1500. Installation can also be costly but non-squareweave isn’t super difficult to install if you want to try yourself.
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 09-14-2019, 02:18 PM
scottrx7tt's Avatar
Headliner is pretty easy if the windows are already removed. I did mine myself and don’t remember having any problems. I also installed my RS full carpet kit myself. Again, I don’t remember having any issues. Door panels are easy if you are just installing some from Appbiz.
Old 09-14-2019, 02:37 PM
Thanks guys.
My glass is out (full repaint) so hopefully that helps on the headliner.
Door panells and pre-formed trim, I agree, should be pretty straight forward. Mainly the headliner that has me wanting professional help.
911 w/ 3.2
Old 09-14-2019, 04:40 PM
