proporsche's Avatar
weber carbs-fitting for power brakes
Hi girl+boys ..anyone has done this?I have here 1978 911SC with Webers..This car has all the power brake equipment in ,it just have to have the air suction on the intake done.Has anybody done this job?
I am guessing it will not take any power away from the carbs....so, just asking for some info about it...
thanx
Ivan
make a nice threaded hole in here for the fitting? Of course on no.3
1985 911 with original 502 191 miles...808 198 km
Old 07-07-2019, 01:34 AM
Vintage Owner
Jack Stands's Avatar
The early manifolds had vacuum ports that allowed you to get engine vacuum. My 914-6 has taps on the two outer manifold runners that have vacuum lines connected to get a signal.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 07-07-2019, 07:40 AM
Vintage Owner
The vacuum lines are removed in the photo, but you can see where they attach. Both lines were connected with a T fitting that then provided a balanced vacuum source with decreased pulsing if there was only one tapped source.
84 Targa (sold)
70 914-6 (sold)
2016 Cayenne
Old 07-07-2019, 08:01 AM
disband
juanbenae's Avatar
I tapped a single line off the middle intake on the driver side manifold w/o any ill effects on my old spec911 with 46mm PMO's.
Old 07-07-2019, 09:01 AM
I went with a high end vacuum pump designed for electric cars. Not an inexpensive route but it’s quiet and works well.
1982 911 Targa, 3.0L ROW with Webers
Old 07-07-2019, 09:51 AM
proporsche's Avatar
thanx guys for the ideas....
Jack.. i will look for the fitting it is a little different what i am facing...
Juan.. i`ll try that if not ok i do the T fitting spit
Ivan
Old 07-07-2019, 10:42 AM
I've used a sporto vacuum tank so you don't run out of vacuum after multiple pumps of the pedal, and a vacuum pump in the smuggler box once. It was kind of noisy, but I'm sure there are quiet ones.
206 637 4071
Old 07-07-2019, 11:04 AM
3rd_gear_Ted's Avatar
Just a related question.
Does a check valve need to be installed to assure proper brake boost operation ALL the time???
Is this a design consideration for both ITB's and Carb conversions?
1980 911 - Metzger 3.6L
2016 Cayman S
Old 07-07-2019, 11:05 AM
proporsche's Avatar
Thanx John.....
Ivan
Old 07-07-2019, 11:35 AM
